HW-450 Samsung Sound Bar - AVS Forum | Home Theater Discussions And Reviews
Old 04-07-2013, 07:12 PM - Thread Starter
Donald K Lomax's Avatar
I was given a sound bar without the remote and connected to my ATT U-Verse DVR box...need some guidance on getting this device to link with my system.
Donald K Lomax is offline
Old 04-08-2013, 05:53 AM
Doctego's Avatar
Liked: 42
Securing a replacement remote or a universal like a Harmony will make your life much easier in the long run. In the interim, is the DVR the only source? If it has an HDMI output, you can connect the DVR to the HDMI IN on the soundbar and then connect HDMI OUT on the soundbar to the TV. Unfortunately, you would have to adjust the inputs and volume manually on the soundbar. On the far right side, you should see the controls. Unfortunately, I think that you need the remote to turn on AnyNet+ on the soundbar.
If you need more assistance, please be more specific regarding the outputs on the DVR, the model # of the TV, etc.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Samsung Hw F450 2 1 Channel 280 Watt Soundbar
