Samsung and Logitech - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-08-2013, 02:07 PM - Thread Starter
rrgman's Avatar
My Logitech Harmony 900 will not turn on my TV and Samsung HWE450 sound bar at the same time. Any suggestions out there?
rrgman is offline
post #2 of 2 Old 04-08-2013, 06:07 PM
Dropkick Murphy's Avatar
Quoted: 71 Post(s)
Liked: 89
First, turn off the HDMI control on your TV (you didn't mention the brand so figure it out yourself).
Next, open up the software and go to devices tab
Click the troubleshoot option on your soundbar device
Choose "Soundbar responds to some commands either too many times or only occasionally"
Click next
Increase the sensitivity to 4 or 5
save and update your remote.
The problem is that the remote is sending out a weak signal and when the TV turns on there is enough interference to block that signal. Increasing the sensitivity will fix it, I've done it many times.
Dropkick Murphy is offline
Reply Soundbars
Logitech Harmony 900 Rechargeable Remote With Color Touch Screen , Samsung Hw E450 Wireless Airtrack Soundbar
