Sound bar advice - AVS Forum | Home Theater Discussions And Reviews
Old 04-09-2013, 05:15 PM - Thread Starter
asutlian's Avatar
I have SONY 55" TV with 20 Watts speaker output. Upon connection to the cable converter the volume need to bring it up at least 60 on a scale of 1-100 for a descent hear of the conversation. If I buy a sound bar with built in sub-woofer, should I look for something more than 20 Watts or what kind of technical capability I need to hear clearly ?
asutlian is offline
Old 04-09-2013, 08:52 PM
mr51's Avatar
Your problem may be with the audio settings of the cable box. I know my Time Warner boxes have a couple of settings in the audio menu that can make a pretty big difference in the volume of the television.
mr51 is offline
Old 04-09-2013, 09:01 PM
Doctego's Avatar
Liked: 42
In addition, I need to manually turn the volume all the way up on my cable box. Not with the remote. Actually hitting the VOL+ button on my cable box until it's maxed out. If I don't, the volume is low or I hear an annoying noise. Once I turn the volume up on my cable box once, I can control the volume on my TV.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Old 04-10-2013, 08:54 AM - Thread Starter
asutlian's Avatar
thanks, for the comment; Yes I do have Time Warner Cable.
asutlian is offline
