Looking for help/advice. Budget: $300 Needs: Connect HDTV/DigiCable Box & HTPC - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-30-2013, 11:04 AM - Thread Starter
Weioo's Avatar
I know almost nothing about audio system but I believe a soundbar is my best bet for upgraded sound from my built-in speakers within my 50" Sammy plasma. My only concern is I won't be able to find something that is able to connect to my HTPC, and my Wii (if possible, but no biggie).
Is there something out there around $300 that sounds decent and can connect to an HTPC? Other than a sound bar, are there any other options I could look into?
Thanks in advance for any an all help!
Weioo is offline
post #2 of 3 Old 04-30-2013, 12:38 PM
Doctego's Avatar
Liked: 42
How exactly will you be connecting everything to the soundbar? HDMI? From all sources?
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #3 of 3 Old 05-06-2013, 11:13 AM - Thread Starter
Weioo's Avatar
HDMI was the plan. Sorry for delayed response, life is quite hectic currently.
Weioo is offline
Reply Soundbars
