Sound bar w/ wireless sub receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 04-30-2013, 05:53 PM - Thread Starter
Drew80's Avatar
Does anyone know of a sound bar with a wireless sub receiver, rather than with an included sub? I already have a sub, and I really have no use for two.
Drew80 is offline
post #2 of 6 Old 05-01-2013, 07:49 AM
force10's Avatar
If you can find a Yamaha YSP 4100 or YSP 5100 then your set. They still jave them on Amazon.
force10 is offline
post #3 of 6 Old 05-01-2013, 08:34 AM - Thread Starter
Drew80's Avatar
Is that the only option? I was not planning to spend that much.
Hell, I've demo'd systems in store that include wireless subs that are FAR cheaper than that.
Drew80 is offline
post #4 of 6 Old 05-01-2013, 08:51 AM
force10's Avatar
Yah and their not as good,you didn't specify your price point.
force10 is offline
post #5 of 6 Old 05-01-2013, 09:08 AM - Thread Starter
Drew80's Avatar
Very true. I guess I hadn't thought about my price point, but it seems you found the upper bound. =)
Drew80 is offline
post #6 of 6 Old 05-02-2013, 02:07 AM
SouthernChick's Avatar
Yep, one that is getting rave reviews from expert reviewers and customers almost everywhere is LG NB3530A. Cost about $269.99 most places right now.
However, from what I have read about this one is that it has no HDMI input slots. It only connects via your TVs (Optical) Audio Out connection on the back of your set.
My understanding of this connection type, (Optical) Audio Out and not HDMI, is that you cannot use your TV's remote to change or turn off/on the volume. You must use the LG soundbar remote to do this.
That being said, in the Amazon.com reviews, many people have said that various models of Logitech Universal Remotes will do the trick e.g. that you can have control of the soundbar, TV, DVD player, etc from those various Logitech universal remotes. Many of the reviewers gave the model numbers of the remotes that worked successfully with this soundbar and their AV equipment.
Here is the Amazon link for the LG NB3530A soundbar:
http://www.amazon.com/s/ref=nb_sb_ss_i_1_5?url=search-alias%3Delectronics&field-keywords=lg+nb3530a&sprefix=lg+nb%2Celectronics%2C284
You can always do a Google search and see what all is out there in whatever price range you choose.
SouthernChick is offline
Reply Soundbars
Yamaha Ysp 4100bl Digital Sound Projector Black , Yamaha Ysp 5100bl Digital Sound Projector Black , Lg Electronics Nb3530a Sound Bar With Wireless Subwoofer And Bluetooth
