How To Disable Internal Speakers Of The VT60??? - AVS Forum | Home Theater Discussions And Reviews
Old 05-03-2013, 08:31 PM - Thread Starter
AuralSex's Avatar
Quoted: 28 Post(s)
Liked: 24
...I got the Z-VOX 555 pedestal soundbar today and hooked it up using the optical audio out jack under the HDMI inputs of the TV. Problem is I can't seem to find a setting that allows me to "tell" the TV that I'm using an external sound system and to disable the built-in speakers. I'm thinking that there has to be a way and that I'm missing something. Can anyone give me a step-by-step procedure to follow to mute the onboard speakers. As it is the sound output is about a half second out of sync between the built-in speakers and the external soundbar.
Any help appreciated.
I feel strongly both ways!
AuralSex is offline
Old 05-03-2013, 08:36 PM
Ozzie Isaac's Avatar
Liked: 101
Try looking under the Viera Link settings. Select Theater instead of TV. That is where it is on an ST30.
Ozzie Isaac is offline
Zvox 555 Low Profile Single Cabinet Surround Sound System With Optical And Coaxial Digital Inputs
