YSP 5100 problems with Apple TV and Viera Link - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-04-2013, 05:53 PM - Thread Starter
rpommer's Avatar
Hi there,
I bought the YSP5100 and my Panasonic Blueray + TV worked fine using Viera Link...now, it doesn't work anymore. I have to use a separate remote for the Blueray.
Also, my Apple TV worked at first but now I can't get any picture+sound through the YSP. I tried to switch HDMI ports and cables, resetting, didn't work! Would appreciate any help!
rpommer is offline
post #2 of 3 Old 05-05-2013, 09:12 AM
force10's Avatar
Quoted: 16 Post(s)
Hi,
Kick the apple resolution down to 1080i or 720P. hook the apple tv straight to the tv to do this and then after that, hook Apple tv back to the soundbar.
force10 is offline
post #3 of 3 Old 05-05-2013, 05:59 PM - Thread Starter
rpommer's Avatar
Hi force10,
Will try and let you know. Thanks!
rpommer is offline
Reply Soundbars
Yamaha Ysp 5100bl Digital Sound Projector Black
