Passive LCR for 32" Tv? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 05-08-2013, 06:03 AM - Thread Starter
majro1972's Avatar
After searching the Internet for days without any luck I figured I would ask the experts here -- does anyone make a LCR passive speaker bar for a 32" TV? The smallest can find is for a 36" tv. Thanks!
majro1972 is offline
post #2 of 5 Old 05-08-2013, 10:42 AM
Phil17108's Avatar
Quoted: 207 Post(s)
Liked: 108
I did not know what LCR is or what you refer to as passive bar is? Just Googled it and found that is a sound bar to use with an AVR or a stereo receiver. I use separate speakers for that. I do know that Vizio has sound bars with wireless subs that are 32 inches. Check Vizio.com for specs.
Phil17108 is offline
post #3 of 5 Old 05-08-2013, 03:37 PM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
I'm guessing a CRT? That's a pretty narrow footprint. Since you are looking for a passive soundbar I'm guessing you have an avr to power it with? If that's the case you might just wan to go with small bookshelf speakers. It's going to be tough to find a soundbar that narrow.
crn3371 is offline
post #4 of 5 Old 05-10-2013, 05:34 PM - Thread Starter
majro1972's Avatar
Thanks Phil17108 and crn3371. Yes basically looking for a non-powered speaker bar that I can use with my AVR. And my wife hates anything wireless so that is not an option. I did find a couple companies that make custom sized speaker bars so maybe I will try that route. Thanks!
post #5 of 5 Old 05-11-2013, 12:25 AM
crn3371's Avatar
Quoted: 240 Post(s)
Liked: 192
How about a bigger tv!
crn3371 is offline
Reply Soundbars
