Sound bar keeps shutting off - AVS Forum | Home Theater Discussions And Reviews
Old 05-09-2013, 01:34 PM - Thread Starter
zschell1984's Avatar
I bought a Sharp sound bar HT-SB60. It will play sound from the TV for awhile, then it just says goodbye and shuts down. How do I turn off the auto show down mode? I want it to stay on until I turn it off.
zschell1984 is offline
Old 05-09-2013, 01:51 PM
Possumgirl's Avatar
Liked: 58
You should contact Sharp tech support. Sounds like you have a faulty bar. It should not shut down as long as it is receiving a signal.
Possumgirl is offline
Sharp Ht Sb60 High Powered Soundbar System For 60 Inch Larger Tvs With Wireless Subwoofer
