where to mount soundbar and place sub-woofer - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-25-2013, 12:36 PM - Thread Starter
agmoreno's Avatar
I just purchased a Samsung hw-fm55c soundbar with wireless sub-woofer at Costco. I am wondering if I can mount the soundbar on a shelf next to my Samsung 55 inch LED TV since the ddv player, etc are on the shelf and I won't have to have hdmi cables running along the wall.
Can anyone provide some guidance if this would sound okay? Also, where should I place the sub-woofer? Can I put it across the room, next to the seating area of our family room?
agmoreno is offline
post #2 of 4 Old 05-25-2013, 01:02 PM
Possumgirl's Avatar
Liked: 58
Soundbars should be placed either just above or just below the TV, otherwise the audio is going to seem disconnected from the picture. Put the subwoofer anywhere you want. Try different locations to see where it sounds best.
Possumgirl is offline
post #3 of 4 Old 05-25-2013, 01:03 PM
crn3371's Avatar
Quoted: 255 Post(s)
Liked: 203
You want the soundbar either directly above, or below, your tv.
crn3371 is online now
post #4 of 4 Old 05-25-2013, 05:09 PM
Doctego's Avatar
Liked: 42
If you have no way to put the soundbar directly above or below yout TV, look at using something like this:
http://www.amazon.com/Sewell-Universal-Soundbar-Bracket/dp/B00823170Y
The subwoofer can go anywhere. Mine is behind my couch.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Reply Soundbars
Samsung Hw Fm55c Premium Slim Soundbar With Wireless Subwoofer And Hdmi Cable , Samsung 55 Inch Led Hdtv Un55b8500
