Just bought a Samsung UN32F5500 32-Inch and need a simple 2.1 bar - AVS Forum | Home Theater Discussions And Reviews
Old 06-04-2013, 12:09 PM - Thread Starter
robnotbob's Avatar
I'd like to keep it simple and use the TV as a switcher using the Samsung's optical output. I'd like the bar itself to be smallish - 40" or less with a sub. I don't want the bar to take up much space, so sticking with a 2.1 setup is fine. This is a pretty small room, say, 7 x 12.
I'll be using this for movies and tv only via Roku, HD cable, and BluRay, no audio - I have a different setup in the living room for that...
I'd like to stay under $200 USD
Considering the VIZIO SB4021E-A0, but am open to any suggestions.
Thanks in advance
robnotbob is offline
Samsung Un32f5500 32 Inch 1080p 60hz Slim Smart Led Hdtv
