Bose 1 SR Soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-20-2013, 08:13 PM - Thread Starter
jrv331's Avatar
Quoted: 20 Post(s)
I set mine up per the manual and it sounds great, but Im stumped on the aux inputs. Per the instructions I hooked the audio optical out from my tv to the in put on the bar. I then hooked up the optical audio from my sat box to the aux optical input and hooked up the digital out from my blue ray to the digital in on the bar.
If i disconnect the optical out from the tv to the bar I get no sound from either source. So if there is no sound output how can I be sure that it is really comparing the sources to pick the best quality? Other than getting a digital switcher and hooking directly to the tv input on the bar I cant get audio unless the bar is connected to the tv.
Hope thats not to confusing, Thanks
JV
jrv331 is offline
Reply Soundbars
Bose Cinemate 1 Sr Digital Home Theater Speaker System
