Vizio 5.1 (S4251w-B4) Sound Bar- Audio will Briefly Cut Out - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 07-02-2013, 08:02 PM - Thread Starter
Nedward's Avatar
I have a new Vizio 5.1 sound bar (S4251w-B4) and I have noticed that when I am playing a 5.1 sound (DD light flashes on when sound begins) it will completely cut out for about 1 second every 15 min or so. I think its the sound bar but wanted to see if you guys thought it could be something else.
Set up is a video file running from a laptop via HDMI to a vizio TV (XVT553SV). This has happens on any source file that causes the DD to flash on the soundbar but does not happen if it is not a 5.1 signal. These are MKV files containing H264 video with AC3 audio (3F2R) made by all different people. Files are played by latest VLC on latest Windows 7. From the tv, which will pass 5.1 AC3 through, the signal goes via the Toslink cable that came with the vizio sound bar to the sound bar optical in.
The only other 5.1 sources I can run to it is my xbox 360 which runs to the sound bar toslink to digital audio coaxial converter and then to the sound bar via digital RCA coax. It does not appear that it happens on the 360 but I use it mainly for gaming so harder to tell perhaps. Also I pick up broadcast HD OTA and don't watch it much but doesn't seem like it happens on that.
What is the most likely culprit? Cables, soundbar, tv, VLC? Anyone experience anything like this?
Nedward is offline
post #2 of 4 Old 02-17-2015, 03:59 PM
Liked: 0
I know this is old but is anyone else having this issue i just installed mine and it seems like the left surround speaker cuts in and out, i have the same model but the 54" sound bar. Vizio 65" m652i i believe is the model tv.
Daniel Pagan is offline
post #3 of 4 Old 11-29-2015, 10:13 AM
Liked: 0
I've noticed this, too. The sound seems to cut out only when I have the 'Tru Volume' feature on. It mostly affects my cable box. When I turn this feature off, the problem seems to go away.
The Hackman is offline
post #4 of 4 Old 11-30-2015, 11:24 AM
mountlaurel's Avatar
I have this model also. I use Dobly Digital with Tivo Premiere and ever since I upgraded firmware to 1017 I lose Dolby Digital when fast forwarding thru commercials. Also notice every once and awhile when changing channels I see the volume lights "Flash like a Streak"
mountlaurel is offline
Reply Soundbars
Vizio S4251w B4 5 1 Soundbar
