Connecting an LG NB3530A Soundbar with a Toshiba 46BL702B - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-04-2013, 07:57 AM - Thread Starter
channy75's Avatar
My Toshiba 46BL702B tv has no optical out point and my LG NB3530A Soundbar only has optical options does anyone know the best way to connect these two devices?
channy75 is offline
post #2 of 2 Old 07-04-2013, 10:05 AM
Doctego's Avatar
Liked: 42
Does your TV have a digital coax output? If so, you can get an adapter like this:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2947&seq=1&format=2
I'd rather do that but, if not, your TV should have a headphone jack. You can connect a 3.5mm cable from that to the soundbar.
What sources do you have? You could also output them directly to the soundbar.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
Reply Soundbars
Lg Electronics Nb3530a Sound Bar With Wireless Subwoofer And Bluetooth
