LG55LA7400 no sound to external speakers - AVS Forum | Home Theater Discussions And Reviews
Old 07-20-2013, 11:53 AM - Thread Starter
mhalper's Avatar
New LG55LA7400 and Panasonic SC-BHT20 home theater unit. Using HDMI ARC out on the speakers connected to HDMI ARC on the TV. TV setting - external speakers HDMI ARC/digital optical cable. No sound. I've also tried using a digital optical cable with no success. My TV input is over-the-air. Any suggestions?
MPH
mhalper is offline
Old 07-20-2013, 01:33 PM
Possumgirl's Avatar
Liked: 58
It seems as though you have the connections correct. You certainly should get audio over optical even if there is some issue going on with the ARC function. Try disconnecting the ARC and just using optical and be sure you're selecting the correct input on the soundbar.
Possumgirl is offline
Lg 55la7400 55 Inch Cinema 3d Led Smarttv
