Sony HT-ST7 high-end soundbar - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #1 of 51 Old 08-08-2013, 10:51 AM - Thread Starter
dsurkin's Avatar
I wonder if this implements surround-sound imaging similar to the Yamaha YSP series?
http://www.engadget.com/2013/08/08/sony-ht-st7-soundbar/#continued
--Dean L. Surkin
dsurkin is offline
post #2 of 51 Old 08-09-2013, 08:26 AM
LDBetaGuy's Avatar
Quoted: 155 Post(s)
Liked: 85
I suppose Sony has done their marketing homework on this soundbar, but $1299.00? Yikes!
LDBetaGuy is online now
post #3 of 51 Old 08-09-2013, 01:10 PM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
I love Sony soundbars, but I wouldn't buy that. That thing is way too expensive. What the fook was Sony thinking?
LexInVA is offline
post #4 of 51 Old 08-09-2013, 06:09 PM
Ozzie Isaac's Avatar
Liked: 101
Looks interesting. Wonder if the sound justifies the price or they just priced it high to make it seem better?
I should add, I'm excited to see more and more offerings. Companies are bound to make better and better soundbars if the competition stays high.
LBJ2 likes this.
Ozzie Isaac is offline
post #5 of 51 Old 08-10-2013, 07:58 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
I just can't justify the expense of a product like that when I can get their second-best soundbar that probably doesn't sound much worse for 1/3 the price or a full Sony 7.1 setup with A/V receiver and speakers.
LexInVA is offline
post #6 of 51 Old 08-10-2013, 11:17 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
HomeTheater.com will have a review of the new soundbar up soon.
LexInVA is offline
post #7 of 51 Old 08-10-2013, 05:10 PM
stracenska's Avatar
I'm considering it because I just bought a Sony tv on Amazon that qualifies it for $300 off. I've had the full speaker system before, but I'm kind of longing for something more simple this time. Sick of wires and complicated menus.
stracenska is offline
post #8 of 51 Old 08-14-2013, 06:02 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
Just go for the HT-CT660. You could get it for next to nothing since you already have a $300 Amazon discount/credit.
Howard Lin likes this.
LexInVA is offline
post #9 of 51 Old 08-22-2013, 11:59 AM
FilmMixer's Avatar
Quoted: 1723 Post(s)
Liked: 2084
Have one one the way...
Let's see if it's worth the hype.
FilmMixer is offline
post #10 of 51 Old 08-28-2013, 04:32 AM
thrang's Avatar
Quoted: 1604 Post(s)
Liked: 1378
Don't know what type of integrated remotes you use, but curious if there is discrete hdmi input selection capability at all, and if it works with any third party control systems.
I use Roomie, and tried the Sony 660, which does have discrete inputs, but none of the controls would work with the Roomie device, not could I teach it via an iTach IR controller. I basically need discrete input, volume, mute ,power, and possibly sound mode for daily use in the kitchen...
thrang is offline
post #11 of 51 Old 08-28-2013, 02:32 PM
FilmMixer's Avatar
Liked: 2084
Mine just arrived today.
I'll report soon.
However I just use my tv remote as I use ARC for all sources.
post #12 of 51 Old 08-31-2013, 06:08 AM
LBJ2's Avatar
I received and set up my new HTST7 a few days back. I've had a chance to play with most of the features and listen to various content. First impressions:
  • Easy to set up ( typical of most sound bar systems)
  • ARC setup works as expected--no issues. My TV remote works just fine for on/off volume etc.
  • Very Unique Remote has received "high design" treatment ( not so sure everyone will find the form-factor useful. Until Logitech includes HTST7 in their Remote database I'll have to use the Sony remote to change Receiver settings )
  • Pretty impressed with how the music sounds ( coming from a sound bar speaker)
  • Bluetooth setup with my iPhone/iTunes was very easy and worked the first time
  • The speaker bar itself is large. I expect this will cover up TV IR sensors on most table top setups. ( IR blaster is included)
  • TV/Blu-ray movies sounds like it's coming from much larger speakers ( doesn't have that sound bar "compressed sound" effect).
Surround sound effect: I am still experimenting with this. Because the shape of the room/furniture etc. has a lot to do with hearing surround sound effects from a sound bar speaker, I want to try setting this speaker bar in a few different rooms. For surround sound effect I am testing with Blu-ray "The Dark Knight" Chapter 20, 1:15:12 - 01:22:25, "Master and Commander" Chapter 4, 08:45 - 11:53, "Transformers: Dark of the Moon" Chapter 17, 1:50:00 - 1:59:58, "The Matrix" Chapter 30, 1:45:18 - 1:51:29.
LB
LBJ2 is offline
post #13 of 51 Old 08-31-2013, 06:10 AM
thrang's Avatar
Liked: 1378
[*] Easy to set up ( typical of most sound bar systems)
[*] ARC setup works as expected--no issues. My TV remote works just fine for on/off volume etc.
[*] Remote has received "high design" treatment ( not so sure everyone will find this very different form-factor useful. Until Logitech includes HTST7 in their Remote database I'll have to use the Sony remote to change Receiver settings )
[*] Pretty impressed with how the music sounds ( coming from a sound bar speaker)
[*] Bluetooth setup with my iPhone/iTunes was very easy and worked the first time
[*] The speaker bar itself is large. I expect this will cover up TV IR sensors on most table top setups. ( IR blaster is included)
[*] TV/Blu-ray movies sounds like it's coming from much larger speakers ( doesn't have that sound bar "compressed sound" effect).
[*][/LIST]
Does the remote have discrete inputs selection button, or must you cycle through? Toggle Power, or separate power on/off?
thanks
fireo likes this.
thrang is offline
post #14 of 51 Old 08-31-2013, 06:20 AM
LBJ2's Avatar
thrang:
Remote Commander : RM-ANU164. Most are toggle/cycle through.
http://www.manualowl.com/m/Sony/HT-ST7/Manual/368154
LB
LBJ2 is offline
post #15 of 51 Old 09-01-2013, 12:12 AM
mi6_'s Avatar
I'm curios to hear what you think of the soundbar. I too prefer a simpler speaker setup.
mi6_ is offline
post #16 of 51 Old 09-01-2013, 06:48 AM
LBJ2's Avatar
I'm still experimenting but I have listened to all kinds of content and tried multiple settings and configurations. I'v e also had a chance to compare directly to my older Sony HT-CT550W sound bar and a Yamaha YHT-S501 sound bar. Sound wise here is my opinion so far :
HT-ST7:
  • Music sounds very good on this sound bar ( which IMO is unusual for a sound bar)
  • Surround sound effect is okay. ( I believe my older Sony HT-CT550W 2.1 sound bar can throw the sound effects further creating a wider sound stage than the HT-ST7 7.1 configuration does)
  • Dialogue can be truly optimized with the Voice mode settings ( this is a great feature for people that need/want enhanced dialogue)
Overall, I think the HT-ST 7.1 sound bar is a very capable, highly engineered/designed device with premium materials. You can clearly see, touch and feel the premium priced components. However, I am not yet sure if I can hear sound enhancements that justify the current premium price. I am curious to read what the professional reviewers have to say about this device when tested in a controlled environment. I know CNET is reviewing the HT-ST7 and is due to post their review any day now.
LB
LBJ2 is offline
post #17 of 51 Old 09-04-2013, 01:38 AM
fireo's Avatar
Im looking to buy this amazing soundbar from sony but can anyone who owns it look at the back and see if it supports 220V as i am in Kuwait. Thanks in advance for your help smile.gif
wolverines0607 likes this.
fireo is offline
post #18 of 51 Old 09-04-2013, 05:27 AM
LBJ2's Avatar
120V 60hz 50w
LB
LBJ2 is offline
post #19 of 51 Old 09-04-2013, 07:29 AM
thrang's Avatar
Liked: 1378
thrang:
Bummer - scratch this off the list.
Thanks....
thrang is offline
post #20 of 51 Old 09-04-2013, 10:16 AM
fireo's Avatar
120V 60hz 50w
fireo is offline
post #21 of 51 Old 11-20-2013, 08:57 PM
greathunder's Avatar
Bringing this thread up again.
I'm currently connecting this soundbar to a KDL65W850A via ARC.
Does this mean that all HDMI inputs on the TV are now using surround sound or do I have to plug them into the soundbar's HDMI inputs?
I also can't tell on the soundbar whether it's using SS or not. I'm reading the manual at the moment but I can't see it anywhere.
greathunder is offline
post #22 of 51 Old 11-21-2013, 05:13 AM
Doctego's Avatar
Liked: 42
With soundbars, especially those with no rear speakers, I would expect simulated surround sound. When utilizing ARC, most TV's output 2 channel audio. You didn't list your TV model so we have no way of knowing whether your TV is the exception or the norm. That said, your soundbar has 3 HDMI inputs so I would connect your sources to the soundbar first for optimal sound and then output the soundbar to the TV via HDMI for video.
773AV likes this.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #23 of 51 Old 11-21-2013, 12:33 PM
Thank you I'll probably connect it straight to the sound bar. As stated earlier I'm connecting it to a SONY KDL65W850A.
post #24 of 51 Old 11-21-2013, 12:49 PM
Doctego's Avatar
Liked: 42
My apologies for missing that. It's been a long week. Either way, I would definitely connect the sources directly to the soundbar whenever possible.
Doctego is offline
post #25 of 51 Old 11-27-2013, 02:30 PM
444video's Avatar
I've had the ST7 set up with my LG 55LM8600 for a few weeks now. I've connect the STB via HDMI to the TV and Optical to the ST7. Thoughts.
  • The soundbar has very clean voice reproduction at all sound levels. As mentioned earlier, Sony has a direct button to increase this range.
  • Set up was a breeze
  • The sub sounds directional no matter where i place it. Maybe a cuttoff frequency issue.
  • Great simple display and dimable.
  • Useless sound modes aside from Movie and Music. Std and music are about the same and Football does nothing to give stadium sound.
My issue has been with the sound separation. I have not felt like it is simulating 5.1 or 7.1 as advertised. The LM8600 outputs LPCM which is supposed to be able to carry multiple channels. There is no TV setting to change the optical output to Dolby. When the SB is connected to STB directly, it does show the Dolby signal.
I wonder if I am getting multi ch on LPCM or if it's just dropping to stereo. ps. I'm using my TV as the 'input switch' so I can get pic profiles for each input.
444video is offline
post #26 of 51 Old 11-29-2013, 11:56 PM
smail.nathan's Avatar
Quoted: 92 Post(s)
Liked: 37
just picked this up - love it so far. great sound, great music playback especially. couple questions:
1. when i stream music to it from my iphone via bluetooth link, my tv screen goes black. should there be any kind of graphical interface up on the tv for the bluetooth to iphone music link? or no?
2. has logitech added this to their harmony database fully yet? i added it to my ultimate remote, but it isnt working with the soundbar yet.
3. has anyone figured out a way to confirm if the soundbar is properly playing hd codecs from sources like a PS4, and dolby digital from a tivo or similar device? i have the output units set up to do that, but it would be nice to have some kind of on screen graphic ( or SOMETHING) showing the soundbar is processing/playing the audio codec in the intended format.
thanks all for your help!
smail.nathan is offline
post #27 of 51 Old 12-02-2013, 04:11 PM
lforigno's Avatar
I just purchased one from my local ABC warehouse for 799.99 brand new. I had to settle for a sound bar because my fiancee does not like the look of speakers in our family room. I was not going to purchase this for full price and I liked the sound of this more than the bose cinemate. I love it thus far.
lforigno is offline
post #28 of 51 Old 12-02-2013, 07:52 PM
Quoted: 92 Post(s)
Liked: 37
great deal there...curious if you're able to answer any of the questions i posed above.
post #29 of 51 Old 12-02-2013, 10:45 PM
Quoted: 92 Post(s)
Liked: 37
ugghh...bit upset right now. was watching blacklist in hd tonight on my nbc affiliate...TONS of cracking from the soundbqr during parts, specifically when cars were screeching on the road during a chase.
havent had this issue during other programs though. it was at volume level 30 in movie mode.
anyone else have this issue with this soundbar? bit worried about this considering its a thousand dollar soundbar...
post #30 of 51 Old 12-03-2013, 04:09 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
I don't know how loud 30 is or if it was a problem with NBC but there is only so much 2.5" speakers can do if trying to play relatively loud. Since then have you heard it on any other channel? Do you have a way to do a frequency test go see if it only happens with higher sounds? I know you can download a lot of test tones.
ttlnb is offline
Reply Soundbars
Sony Htst7 Hd Sound Bar With Wireless Subwoofer
