Sounbars as rear speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-08-2013, 10:51 AM - Thread Starter
sr1nath's Avatar
I have a 5.1 setup with full range floor-standing fronts and a potent center speaker. My rear wall does have lot of windows limiting the space for surround speakers. There is about 18" space between the windows, all the way from floor to ceiling.
I know, I can hook up small satellite speakers and tilt them down in an angle. I am wondering if I could install long/flat speakers like soundbars between the windows to play as rears. Is there any issue with that?
Can someone recommend any such speaker or soundbar? It should be able to take standard speaker wire (5 way binding posts) and play. I don't need any digital/analog inputs on them.
sr1nath is offline
post #2 of 5 Old 08-08-2013, 11:05 AM
Possumgirl's Avatar
Liked: 58
Bad idea. Active (powered) soundbars wouldn't work. Passive soundbars might work by connecting only one of their three speakers, but you would be spending a fortune compared to two small satellite speakers.
Possumgirl is offline
post #3 of 5 Old 08-08-2013, 04:57 PM - Thread Starter
sr1nath's Avatar
@Possumgirl, Thanks for the reply.
Leaving aside the soundbars, can I use LCR type speakers as rears (vertically placed)? Here are some examples:
Paradigm Millenia 20, Millenia LP
DefTech Mythos XTR-40, Mythos Seven
These speakers have one pair of binding posts (1 channel). Tweeter is placed at the middle of the speaker, so I can mount it at ear level.
I know it is pricy/overkill for surrounds, but do you see any issue with such setup.
sr1nath is offline
post #4 of 5 Old 08-08-2013, 06:26 PM
Possumgirl's Avatar
Liked: 58
I would think either of the speakers you listed would work fine. It's your money. biggrin.gifbiggrin.gif
post #5 of 5 Old 08-19-2013, 06:58 PM
xFreshEntrailsX's Avatar
Quoted: 60 Post(s)
Liked: 392
Martin logan motion slm is pretty much the same .. heard them before .. they sound good
Onkyo TX-NR929, QSC GX5, Polk Audio RtiA9's, CsiA6, F/XiA6's, RtiA3's,PSA xs30se, Xbox 360, PS3, hopper w/Sling, Samsung 55" LED, All controlled with a Harmony One
xFreshEntrailsX is offline
Reply Soundbars
Definitive Technology Xtr 40 Ultra Thin On Wall Lcr Speaker
