Need help with connecting Samsung HW-F355 Soundbar. - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2013, 01:25 AM - Thread Starter
BeyondBelief's Avatar
Hello everyone.
I bought this soundbar for a friend recently and we can't seem to connect the tv to the soundbar. He has a hisense ltdn42v77us and it is quite a low budget tv but the only audio out is an orange RCA coaxial one, no optical or even L/R RCA out. The soundbar has two options for connecting to a tv, either optical (which the tv doesn't have) or analogue. The cable which is provided is an auxiliary (which plugs into the bar) to L/R RCA cable (supossed to plug into tv) but the TV does not have the L/R out, just the orange coaxial. What are the options to make this work? We have tried plugging in just one of the RCA but sound only slightly came out the corresponding speaker on one side of the bar. I saw no info on any cable that is Aux male to RCA male. Is there a type of adapter or something we could use?
BeyondBelief is offline
Old 08-31-2013, 11:21 AM
Possumgirl's Avatar
Liked: 58
The orange connector is digital coax. The soundbar uses digital optical. You just need a converter like this one, plus the cables of course.:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10423&cs_id=1042302&p_id=2947&seq=1&format=2
Possumgirl is offline
Samsung Hw F355 2 1 Channel Soundbar
