Soundbar blocking tv - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-01-2013, 07:20 AM - Thread Starter
Hip2bSquare's Avatar
So the Vizio soundbar blocks the bottom part of my tv.
Is there some kind of furniture i can buy or some way besides mounting anything that i can raise my tv up about an inch or so?
Like something that i can sit the attached tv stand legs from the tv on?
Hip2bSquare is offline
post #2 of 2 Old 09-03-2013, 08:13 PM
Wheels_32's Avatar
Quoted: 27 Post(s)
Hip2b....glad you posted this. I have the same concern. I really want to add a soundbar to be just a soundbar during normal TV watching and get better audio, and then serve as a center channel when using the receiver. I have the same concern that any soundbar speaker is going to cover the bottom of the TV...I can't find any that are very low profile. I do not mount my TV on the wall, it sits on the supplied legs/base. Not sure what to do!?!?! I hope you get some good ideas in your post!
Wheels_32 is offline
Reply Soundbars
