help with philips htl5120 bass and treble indicator - AVS Forum | Home Theater Discussions And Reviews
Old 09-11-2013, 11:41 AM - Thread Starter
TitanDesigns's Avatar
Hi there this is really a question for any htl5120 owners. The manual says that like the volume, you can see the indicator lights on the bar light up as you increase treble/bass or go down as you decrease. However mine just arrived and this isn't the case, just one light activates to acknowledge each button press of the remote but not sure if it's working or if im reaching maximum output.
Any ideas would be greatly appreciated.
TitanDesigns is offline
Old 12-03-2013, 02:32 PM
nebunuvoda's Avatar
hello. i want to buy this sound system. is it ok? any 5.1 experience? thanks
Sent from my Nexus 7 using Tapatalk
nebunuvoda is offline
Old 06-25-2014, 06:36 PM
Stewrt's Avatar
Originally Posted by TitanDesigns View Post
Hi there this is really a question for any htl5120 owners. The manual says that like the volume, you can see the indicator lights on the bar light up as you increase treble/bass or go down as you decrease. However mine just arrived and this isn't the case, just one light activates to acknowledge each button press of the remote but not sure if it's working or if im reaching maximum output.<br><br>
TitanDesigns,
As one of the only owners of this sound bar, and because I'm considering it myself, I'm wondering if you were able to resolve your problem with adjusting the treble and bass. I'd also like to know how you like the bar?
Hoping you were able to work out your problem,
Stuart
Stewrt is offline
Old 06-26-2014, 01:32 AM - Thread Starter
Hi there Stewrt,
Yes, in the end I found out that essentially it is a single light that indicates the status/level of the treble and bass. There are 8 lights in total, and as you increase/decrease with the remote, the lights with pulse dimly then light up in full, before moving onto the next, until it reaches the 8th one. You know when its at the max when the final led becomes slightly brighter than it was before, reaching its full brightness means its hit the top.
It's not the most intuitive method by far, and should have been detailed more in the manual, but it works. What is strange, is that to get that loudness and treble and bass, even at their max settings, you have to turn the SoundBar on, then turn Audio Volume on the remote Off, then press On again, for a marked difference in sound.
Other than that, Im happy with my purchase still after all this time, its an improvement over the Samsung UE55f8000 built in speakers for sure, but mainly due to the low cost rather than performance. In the last week funnily enough, Ive ordered two Sonos Play:1s and a bridge to begin the process of paying a home theatre Sonos setup (just need the play bar and sub woofer to complete) and the stereo set up of a pair of Play:1s already sounds better/meatier than the single play bar, Im looking forward to the full set up to see how much better it becomes.
I intend to keep the HTL5120 but place it in a different room/office area as its definitely an improvement over normal tvs, just maybe not the wow factor you were hoping for with a single piece of kit. The Sonos set up is expensive, and Im sure more learned audiophiles would say its better to buy a proper audio set up for half the price, but Im already in love with the wireless nature (reason I bought the HTL5120 in the first place was to remove clutter) and the ability to push music into other rooms.
Hope that helps, all the best,
Leo
Philips Htl5120 F7 Bt Hdmi 120w Soundbar Speaker
