Vizio sound bar, need help! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-25-2013, 10:53 AM - Thread Starter
ewhittin's Avatar
I just purchased a Sony blu ray player BDP-S3100 and I need information on how to connect it to my vizio sound bar. I am not very tech savvy so please be patient with me lol. The blu ray only has a coaxial output. Can anyone help?
ewhittin is offline
post #2 of 6 Old 09-25-2013, 12:08 PM
Possumgirl's Avatar
Liked: 58
What model Vizio soundbar do you have? They make several and they don't all have the same inputs. What inputs does yours have?
Possumgirl is offline
post #3 of 6 Old 09-25-2013, 01:41 PM - Thread Starter
ewhittin's Avatar
I can't remember what model it is but it has the RCA red and white cables.
ewhittin is offline
post #4 of 6 Old 09-25-2013, 02:42 PM
Possumgirl's Avatar
Liked: 58
Really need the model number or what other inputs it has besides RCA in order to provide advice.
post #5 of 6 Old 09-25-2013, 05:28 PM - Thread Starter
ewhittin's Avatar
Model # VSB210WS it has the RCA cables and a SP/DIF input that's it. My Sony blu ray only has a digital audio coaxial input
ewhittin is offline
post #6 of 6 Old 09-25-2013, 05:55 PM
Possumgirl's Avatar
Liked: 58
Your BD player has HDMI out. You can connect it directly to your TV. Assuming your TV has optical audio out, you can then connect it to the optical input on the soundbar. Hopefully the TV automatically outputs PCM or there is a setting on the TV where you tell it to output PCM. The soundbar can only accept PCM on its optical connection. Try that and let us know if it works. If not there is another method, but let's try the easy one first. wink.gif
Reply Soundbars
Sony Bdp S3100 Blu Ray Player , Vizio Vsb210ws Universal Hd Sound Bar With Wireless Subwoofer
