Budget Sound bar with HDMI in and HDMI Out? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 09-26-2013, 05:37 PM - Thread Starter
jbrady3324's Avatar
Quoted: 20 Post(s)
I am looking for a sound bar for my bedroom Pioneer 500m. I want the sound bar to replace my receiver so I need one that has HDMI IN and HDMI OUT as the Pioneer does not have Optical Out and neither does the Roku that will be hooked up to the TV
I prefer a sound bar without a subwoofer or where the HDMI inputs are on the actual sound bar, if possible
Pioneer KRP-500m
Panasonic 65VT50
M&K LCR-750s Fronts and Center
M&K M-4T Surrounds
X-Rite i1pro
jbrady3324 is offline
post #2 of 12 Old 09-28-2013, 03:06 PM
Doctego's Avatar
Liked: 42
What dollar amount qualifies as budget to you?
tubetwister likes this.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
post #3 of 12 Old 09-28-2013, 05:14 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Good question!, (thumbs up)
some sound bars can get pretty spendy now some of higher end names are getting into sound bars now and charging plenty!
tubetwister is offline
post #4 of 12 Old 09-29-2013, 07:38 AM - Thread Starter
jbrady3324's Avatar
Quoted: 20 Post(s)
Well, lets say $100-$400. My budgets are typically wide as I always want to buy what is the best value for what I am trying to achieve.
I have the Samsung HW-F450 on order right now. From what I read and could see, it appears the hdmi connections are on the back of the sound bar which is definitely a requirement for me
Pioneer KRP-500m
Panasonic 65VT50
M&K M-4T Surrounds
X-Rite i1pro
post #5 of 12 Old 09-30-2013, 04:13 PM
Fred2004's Avatar
I'm in the same boat. I have a PS3, Xbox, and Cable and my TV only has 2 HDMI in's...I was thinking of getting the andrew jones soundbar for $399 but its only on optical out...
Should I get a receiver (with HDMIx4 in and out x1) or should I get a switch?
Was thinking of just getting hte Andrew Jones book shelf speakers and using that w/ a reciever...but i'd like to spend ~$300...
Sound is important...but I am deaf in my left ear so I only hear in MONO so surround sound does absolutely nothing for me, though i would like better sound than the crappy speakers on the tv.
Thanks for the advice.
thinking of just getting this switch "pigtail" for $15
http://www.bestbuy.com/site/3-x-1-hdmi-switch-pigtail/1307202395.p?id=mp1307202395&skuId=1307202395&st=hdmi switch&cp=1&lp=2
Fred2004 is offline
post #6 of 12 Old 10-01-2013, 09:47 AM
wallijonn's Avatar
Yamaha YHT-S401 - 3 HDMI in, 1 out. $400. If you like a sub woofer. Too bad you want HDMI. The Yamaha YSp-1400 has built in sub-woofers inside the sound bar. Optical/digital in only, though.
But I'm also looking at the YSP-2200 for under $800.
wallijonn is offline
post #7 of 12 Old 10-01-2013, 10:13 AM
Fred2004's Avatar
thanks!
the more I'm thinking about it, the more I think i will just get a switch and the Andrew Jones soundbar...that receiver seems like a pretty killer deal though.
Fred2004 is offline
post #8 of 12 Old 10-01-2013, 10:35 AM
shamus's Avatar
Quoted: 23 Post(s)
Sony seems to have those options
Fred2004 likes this.
shamus is offline
post #9 of 12 Old 10-01-2013, 11:12 AM
Fred2004's Avatar
thanks...I came across the HT-CT150 and am seriously thinking about just getting that since it has 3 HDMI in's and it's only $200...
Fred2004 is offline
post #10 of 12 Old 10-01-2013, 12:02 PM
shamus's Avatar
Quoted: 23 Post(s)
I think thats an old model? Check out the 260 for same price. Fyi, I havnt heard any of those models.
shamus is offline
post #11 of 12 Old 10-01-2013, 03:39 PM
Fred2004's Avatar
ah, correct sir... went to local bestbuy at lunch and saw a Sony HT-CT660 which has 3 HDMI in's on the bar which I thought was pretty cool...listed on amazon for $345
Fred2004 is offline
post #12 of 12 Old 10-01-2013, 10:11 PM
wallijonn's Avatar
Reply Soundbars
Samsung Hw F450 2 1 Channel 280 Watt Soundbar , Yamaha Ysp 2200 Digital Sound Projector Black , Yamaha Yht S401bl Front Surround Home Theater System , Sony Ht Ct150 Virtual 5 1 Channel Sound Bar And Subwoofer Set Accessory Kit , Sony Ht Ct660 46 Inch Sound Bar With Wireless Subwoofer
