LG NB3530A cutting off the first few milliseconds of sound? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-05-2013, 12:22 PM - Thread Starter
adster's Avatar
I have both the LG NB3530A Soundbar and the LG 55LA7400 TV.
When using optical (both using LG Sound Sync Optical and regular Optical settings on the TV/Bar) the first few milliseconds of sound is missing. What I mean by this is what when navigating menus (like my TiVo or Apple TV) you can't hear the menu navigation sound unless you move very fast or repetitively, thus "stacking" the sounds on top of each other. This does not happen when I'm using the LG Sound Sync Wireless options, however.
Anyone with the bar have an idea why it's doing that? I might try some troubleshooting and using a direct optical instead of outputting from the TV to see which one is causing the issue.
Thank you!
adster is offline
post #2 of 3 Old 10-05-2013, 03:10 PM - Thread Starter
adster's Avatar
Here's a vide of the issue.
adster is offline
post #3 of 3 Old 11-16-2013, 12:28 AM
busdriver197's Avatar
Hi- I have this soundbar and mine does the same exact thing. I have it hooked up to a Samsung 51" plasma using the optical out from the back of the TV directly to the soundbar. When I use my Roku or PS3, I notice the sound being cut out for the menu beeps. However, I noticed that it isn't actually being cut out. I put my ear right next to the bar, and I can hear the sound VERY faintly if not rapidly using the Roku or PS3 remote. Have you figured out anything else on the issue?
busdriver197 is offline
Reply Soundbars
Lg Electronics Nb3530a Sound Bar With Wireless Subwoofer And Bluetooth , Lg 55la7400 55 Inch Cinema 3d Led Smarttv
