Should I power on and off every time? - AVS Forum | Home Theater Discussions And Reviews
Old 10-12-2013, 08:36 AM - Thread Starter
ddt
ddt's Avatar
Is it best to power off a sound bar when it is not in use, or is it perfectly fine to leave it on 24/7. I have a Vizio VHT210.
ddt is offline
Old 10-12-2013, 08:52 AM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I wouldn't leave it on and why would you want to do that?
colour is offline
Old 10-12-2013, 03:10 PM - Thread Starter
ddt
ddt's Avatar
Just the hassle of turning it off and on every time I turn the TV on and off. Have been turning it off all along, just wondering if it was unnecessary.
ddt is offline
Old 10-12-2013, 03:30 PM
kbeam418's Avatar
Location: 41.7080574, -83.5911255 N41° 42.4834', W083° 35.4675'
Liked: 47
There shouldn't be any problem with leaving the sound bar on 24/7. The only problem might be the electricity cost. The big advantage, although this a theory, is it will be warmed up so you'll get the best sound quality.
"Then one day you find ten years have got behind you no one told when to run you missed the starting gun."
kbeam418 is offline
Old 10-12-2013, 04:54 PM
colour's Avatar
Quoted: 13 Post(s)
Liked: 38
I use a Harmony remote for my bedroom setup with sound bar, powers everything on or off with one button.
colour is offline
Old 10-12-2013, 05:56 PM - Thread Starter
ddt
ddt's Avatar
That would be a solution, I guess. What do most people do?
ddt is offline
Old 10-12-2013, 05:59 PM
kbeam418's Avatar
Liked: 47
Program the sound bar to their remote. Do have cable/ satellite? Because if you do you can program it to that remote.
kbeam418 is offline
Old 10-14-2013, 02:45 PM
Jasonn B's Avatar
Quoted: 303 Post(s)
Liked: 119
A lot of newer soundbars have bluetooth and you phone will connect to it for music. So if it's always on, it's convienent to not have to turn it on just to play music.
80" Vizio LED - (60" Vizio plasma - retired)
Harmony 890 Remote
X10 Commander Iphone App = full control of lights, fireplace, pool, shades, from Iphone
X10 IR543 controller
Hunter Douglas motorized shades
Jasonn B is offline
Vizio Vht210 2 1 Home Theater Soundbar With Wireless Subwoofer Black
