Yamaha YSP 2200 placement of subwoofer - AVS Forum | Home Theater Discussions And Reviews
Old 11-05-2013, 07:43 PM - Thread Starter
NatJev's Avatar
Hello
I just got my new YSP 2200 which is pretty good!
I do have a problem however. I have the subwoofer in my cabinet right under the soundbar and when there is a lot of action the entire cabinet rattles.
Can you put the subwoofer anywhere in the room or does it have to be directly under the soundbar? I would like to move if a few meters off to one side if possible to stop the cabinet rattles. biggrin.gif
thanks
Nat
NatJev is offline
Old 11-06-2013, 12:18 PM
Doomas's Avatar
You should be able to place Sub anywhere you like, only then you need to do calibration of unit again. I am looking forward to buy 2200, maybe you can drop me small review of Yamaha from your self, any good ? any bad points ?
HTPC - Was is das ???
Doomas is offline
Old 11-06-2013, 01:47 PM
drfreeman60's Avatar
Liked: 52
For the absolute best sound the woofer should be as close to the plane of the soundbar as possible. One or two meters to the side should still render acceptable sound. Further than that and you have an issue with a portion of the mid to upper bass is coming from one location and the midrange and treble are coming from a second location. Depending on the size of the room, you may never notice.
Yamaha used to offer the option to reverse the phase of the woofer in the event that it was either out of plane with the tweeter or too far away. I tested a 2200 two years ago but for the life of me, don't remember whether that is still an option or not.
One thing for sure, out of the cabinet will definitely be better.
David
David Freeman
drfreeman60 is offline
Yamaha Ysp 2200 Digital Sound Projector Black
