Per amazon and macmall.com
103dB of room-rocking, crystal clear sound with less than 1% total harmonic distortion
Deep Bass Modules add serious low end frequency without the need for an external subwoofer
Connect to your TV with an easy, one-cable setup - HDMI-in, HDMI-out (ARC), analog and digital input options (all cables included in the box).
Wirelessly stream your music from a smartphone or tablet via Bluetooth. Sound Pressure Level measured using pink noise at 1 meter, C-weighted. Total harmonic distortion calculated as electrical measurement of amplifier distortion.
Source Bluetooth playback device must be enabled with aptX technology. See your Bluetooth device's specifications for details.
http://www.amazon.com/VIZIO-S5430W-C2-54-Inch-Soundbar-Black/dp/B00E1EUX6M/ref=pd_rhf_se_p_tnr_2
http://www.macmall.com/p/Vizio-Home-Audio/product~dpno~9797187~pdp.iebcigg
Technical Data
Specifications
Sound bar Size : 54”
Sound bar Speakers: Left & Right Channels (each) – 2x 3.0” Full-range drivers, 4.0” Deep Bass Module
Sound bar Center Channel - 1x 3.0” Full-range driver
Sound Pressure Level- 103dB
Sound Bar Frequency- 60Hz - 20kHz
Audio Decoding Technology- Dolby Digital®, DTS Digital Surround™
Sound Enhancement Technology- DTS TruVolume™, DTS TruSurround™, aptX®
Bluetooth- Yes
Sound bar buttons- Power, Input, Bluetooth, Volume Up, Volume Down
Remote- Yes – Display Remote
Power Input- 120V 60Hz
Installation- Table top and wall-mountable
Package Contents- Sound Bar, Display Remote, RCA to 3.5mm Audio Cable, Digital Coaxial Cable, Optical Digital Cable, Wall mounts, Quick Start Guide, Sound Bar Power Cable
Connections (Rear)
Analog Audio Input: 1x Stereo RCA
Analog Audio Input: 1x 3.5mm Stereo Audio
Digital Audio Input: 1x RCA (Coaxial)
Digital Audio Input: 1x Optical (Toslink)
Digital Audio Input: 1x HDMI-in
Digital Audio Output: 1x HDMI-out (ARC)
Subwoofer Output: 1x Subwoofer Out
USB Input: 1x USB (for .WAV playback)
Technical Data
Specifications
Bluetooth- Yes
Connections (Rear)
