ht-ct260 sound settings - AVS Forum | Home Theater Discussions And Reviews
Old 11-10-2013, 05:11 PM - Thread Starter
dinosaur1's Avatar
Can anyone recommend what sound settings they use for this sound bar? I use it in my rec room and I am trying to get it to deliver the best sound possible? Also, where should the sub be placed?
I am considering the Vizio S4251w-B4 because of the 5.1 experience.
dinosaur1 is offline
Old 11-11-2013, 05:12 PM - Thread Starter
dinosaur1's Avatar
Anyone?
Old 11-24-2013, 07:49 AM - Thread Starter
dinosaur1's Avatar
Any help?
Sent from my iPhone 5S using Tapatalk
Old 11-25-2013, 04:11 PM
linetest's Avatar
I bought one of these to try. On the tone menu I have bass maxed. On the subwoofer volume I have it max at +6. I redid the pairing even though light is green. I can feel some vibration with my hand touching the speaker cone, but otherwise no bass at all. I see folks complaining bass may be too much. I wonder if I got a bad system. The sub does work, but weak is an understatement. Ideas?
linetest is offline
Vizio S4251w B4 5 1 Soundbar
