Sony HTCT260H Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-18-2013, 09:05 AM - Thread Starter
TLS1979's Avatar
I recently purchased this sound bar and have it hooked to my Sony KDL46HX850 via HDMI-ARC.  The two products sync together.  The problem I am having is that everytime I turn the power off on the systems and then turn the power back on, the sound bar defaults back to OPTICAL option, even though I do not have it set up that way.  I was curious if anyone knew how I can get the sound bar to automatically default to the HDMI display so I don't have to manually change the input on the sound bar everytime it is powered on.  Thank you.
TLS1979 is offline
post #2 of 5 Old 11-18-2013, 09:31 AM
st24a's Avatar
Ok, silly question but did you make sure you hooked up to the HDMI-ARC input and not to the HDMI input (which is right next to the HDMI-ARC input)?
ARC technology is available only when the Control for HDMI function is set to on. If the Control for HDMI function is set to off, use a digital optical cable.
Set “TV AUDIO” in the AMP menu to TV(HDMI) - it's default setting is Optical.
Hope this helps.
st24a is offline
post #3 of 5 Old 11-18-2013, 06:12 PM - Thread Starter
TLS1979's Avatar
Thanks for the help.  I needed to switch the TV AUDIO to TV (HDMI)
TLS1979 is offline
post #4 of 5 Old 11-18-2013, 06:53 PM
st24a's Avatar
Anytime. Glad to have been of assistance.
st24a is offline
post #5 of 5 Old 12-06-2013, 10:27 AM
thomasr1950's Avatar
I have the same unit. I can't get the subwoofer to connect to the soundbar. After going thru all the steps it says FAILED, it won't connect. Sony doesn't know of a fix.
thomasr1950 is offline
Reply Soundbars
Sony Htct260 Sound Bar Home Theater System , Sony 40 Inch 3d Hdtv Kdl46hx850
