Soundbar vs Stereo speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 12-17-2013, 09:54 AM - Thread Starter
myxahmkn's Avatar
Hello - hope I can get some advice.
I have an onkyo ht-x22hdx with 2 speakers (Onkyo HT-X22HDX 3D Ready Ultra Compact 2.1 Home Cinema System: Amazon.co.uk: TV which is miles better than the TV speakers, but doesn't really give ay kind of surround sound effect.
At the time I purchased it, I was told that this would beat most soundbars and I have been wondering recently if that is still the case as it's beena  few years now. I have limited space so a long soundbar isn't really practical, but I keep seeing smaller ones pop up all the time and wonder if they would give me a nicer sound.
It's also xmas and I'd like to buy myself something :)
Ones I have been interested in are
Creative D5XM: Creative D5xm Premium Smart Modular Speaker System with Bluetooth for Apple iOS and Android Devices: Amazon.co.uk: Hi-Fi & Speakers
Sonos Playbar: Sonos PLAYBAR Soundbar and Wireless Speaker: Amazon.co.uk: TV
Denon DHT: Denon DHT-T100 Soundbar for TV - Black: Amazon.co.uk: TV
I will mainly use it for TV, movies, XBOX and also streaming music from Android / iOS devices, My current one can't stream music but if the advice is to stick with that I understand I can get a bluetooth adapter.
My tv stand is only 80cm wide hence looking at smaller soundbars, and my tv is in a corner. Though I will be moving next year so this will change.
I have no real way of testing these or hearing them, hence joining this forum and asking the question in the hope that someone more knowledgable can help.
myxahmkn is offline
post #2 of 15 Old 12-17-2013, 10:46 PM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
In general I would say that it is true that a good 2.1 system will blow away a sound bar for sound quality. Your system uses small full range speakers and not speakers with a woofer and a tweeter, so in your instance you might have better luck with a sound bar. If you can go with a better 2.1 system that has larger speakers it will be difficult or a sound bar to match. I have heard the Sonos bar and it is one of the better sounding bars but I still chose a 2.1 system over it. I would recommend the sub with it.
ttlnb is offline
post #3 of 15 Old 01-29-2014, 12:42 AM
dark1x's Avatar
Quoted: 13 Post(s)
I have to weigh in on this. I did purchase a Denon DHT-T100...and I'm taking it back today.
The quality just isn't there. The living room TV is quite thin and the Denon produces better sound than it, but that isn't saying much.
I have a small T-amp lying around which I used to compare the OWM3 Polk speakers (extra surrounds that I had laying around) and, oddly enough, the speaker bar from my Kuro plasma (which is used in my theater room). The OWM3 speakers completely blow away the Denon on their own but it was more surprising to me that the Kuro speaker bar actually sounds better than the Denon as well. Once I made that comparison I knew I had to return the Denon and just buy a receiver instead. I wanted to avoid the mess of mounting speakers and buying extra components this time but the sound quality just isn't good enough on its own and I won't be happy with it.
dark1x is offline
post #4 of 15 Old 02-02-2014, 10:17 AM
bear123's Avatar
Quoted: 1706 Post(s)
Liked: 2511
TV speakers to the best sounding sound bar is probably equivalent to the best sounding sound bar as compared to a cheap 3.1 setup.  Even the most inexpensive speaker setup will be a drastic improvement over a soundbar.
bear123 is online now
post #5 of 15 Old 02-02-2014, 10:22 AM
mercennarius's Avatar
Quoted: 75 Post(s)
Liked: 35
Beg to differ. Soundbars like Vizios S4251 actually sound as good or better then a low end 5.1 setup.
mercennarius is offline
post #6 of 15 Old 02-02-2014, 04:00 PM
bear123's Avatar
Liked: 2511
If all one has ever heard is a soundbar compared to tv speakers, I am sure they sound impressive.  Bose fans think their setups sound great.
post #7 of 15 Old 02-02-2014, 04:55 PM
Quoted: 75 Post(s)
Liked: 35
I had a "low end" Samsung 5.1 before the Vizio S4251, the Vizio sounds better and provides a more immersive surround experience. Had a Magnavox 5.1 before that which the Vizio matches in experience.
post #8 of 15 Old 02-02-2014, 05:06 PM
bear123's Avatar
Liked: 2511
Well, I am not really including plastic "home theater in a box" wal mart 5.1's.  Sorry I had not even considered including those, I should have qualified my statement better.  But any real 5.1 speaker set up, even as low as the energy take 5.1 for like $380.  However, one must have or purchase an AVR in order to use speakers, so it would be tough to come out much less than $600, although there are even cheaper speaker setups than the energy.
For $200 or so, I can see a soundbar as a better alternative to tv speakers.  But beyond that I believe it makes sense to switch to an inexpensive AVR and some real speakers.
post #9 of 15 Old 02-03-2014, 09:54 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
dark1x,
One thing you could consider depending on your TV is powered speakers. If your TV has and audio or headphone out you can hook up speakers to it and not use the receiver. This is the route I took and I split the signal and added a subwoofer. It works out great and one less component in the mix. Some of the speakers that I liked when demoing were. JBL LSR-305 and LSR-308, Paradigm Shift A2 and Millennia CT, Genelec G series, Focal Solo, Neumann. There are many others as well but any of these really destroyed any of the sound bars that I also tried. If you go the receiver route there are even more options for speakers.
ttlnb is offline
post #10 of 15 Old 02-04-2014, 01:32 PM
tim1000's Avatar
with a soundbar how does the hdmi in/out work, how is the video sent out? I was looking at sony 1040 reciever and it has 4k hdmi up conversion, so the sony must be doing something to the video? do soundbars act like a reciever?
are soundbars only 1080p?
tim1000 is offline
post #11 of 15 Old 02-12-2014, 02:19 PM
drfreeman60's Avatar
Liked: 52
Tim
Why in the world would any of this matter? Do you have a 4K TV? If so, why would you route your video through a receiver or a soundbar unless you knew the upscaling chip in the audio unit would outperform the unit in your TV. Since there is little native content in 4K, it would be extremely difficult to see a difference.
If you are sending your output to a standard 1080p or less TV, you would certainly not want to upscale to 4K as then your TV would have to downscale. You would only make your picture look worse (much worse) than if you did nothing at all.
David Freeman
drfreeman60 is offline
post #12 of 15 Old 02-01-2015, 03:49 PM
Liked: 0
anyone heard of the focal dimension. any ideas what it is like for sound quality - stereo sound and movies? anyone have one?
dwilkins98 is offline
post #13 of 15 Old 02-01-2015, 09:11 PM
Quoted: 950 Post(s)
Liked: 479
I haven't heard the Focal but they make nice speakers and drivers. For something in this price range I would try to listen to Focal, Paradigm, Martin Logan, B&W, Def Tech or one from another respectable speaker company and see what you prefer.
Ellebob is offline
post #14 of 15 Old 02-01-2015, 09:19 PM
John Sully's Avatar
Quoted: 216 Post(s)
Liked: 150
I haven't heard one, but have read a review which said that it was really good, especially with the optional sub. A local dealer sells them (I didn't listen because I don't want a soundbar) and he says that he sells a lot of them to older customers who can't understand their TV speakers anymore!
Theory is a great place, everything works in theory.
Receiver: Denon AVR X3000
Blu-Ray: Sony BDP-N460/LaserDisc: Panasonic AG-LD20
Satellite: Dish Hopper w/Sling
Speakers: SVS Prime Tower/SVS Prime Center/SVS Prime Surround/Velodyne HGS-15
John Sully is offline
post #15 of 15 Old 02-16-2015, 10:52 AM
Quoted: 22 Post(s)
Liked: 1
Unfortunately, sometimes even a 2.1 system can be impractical like in a bedroom wherein my wife will not want to see wires or speakers on stands (since I already have another room for home theater).
So if I can have a good high quality soundbar even if it costs almost like a basic 5.1 system, I'd appreciate it.
speed_kills is offline
Reply Soundbars
Sonos Playbar Tv Soundbar And Wireless Speaker For Streaming Music , Vizio S4251w B4 5 1 Soundbar
