Sony HT CT260 Wireless issues/crashes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-21-2013, 11:32 AM - Thread Starter
mountainmohawk's Avatar
Hi everyone,
My friend recently got the Sony HT CT260 soundbar system and is having issues with it. Whenever he turns it on, it disconnects/disables wifi on his PS4 and other devices.
Any help or ideas?
mountainmohawk is offline
post #2 of 2 Old 12-22-2013, 07:56 PM
Hwaiting's Avatar
It must be some kind of interference? I figure the wireless sub and the bluetooth on the soundbar operate at same 2.4Ghz frequency as the wifi on the PS4.
Try turning off bluetooth on the soundbar first and see if that works. If you still have issues, try turning off the wireless sub to see if that's the culprit.
Another option is to try using another 2.4Ghz Channel on your router and see if that makes a difference.
Hwaiting is offline
Reply Soundbars
Sony Htct260 Sound Bar Home Theater System
