Soundbar remote - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-22-2013, 06:28 PM - Thread Starter
lecineg's Avatar
Is there a soundbar that can be controlled by the DirecTv Remote?
lecineg is offline
post #2 of 2 Old 12-27-2013, 08:17 AM
dealer6871's Avatar
Quoted: 13 Post(s)
I control my Zvox 555, cable box and Panasonic Plasma all from my Time Warner remote. The remote controls on/off of all devices with one push of the power button. Also the volume. Should also work for your Direct TV remote. Good solution if you can fit a Zvox box into your system.
dealer6871 is offline
Reply Soundbars
Zvox 555 Low Profile Single Cabinet Surround Sound System With Optical And Coaxial Digital Inputs
