Golden Ear soundbar or Martin Logan motion soundbar ? - AVS Forum
post #1 of 4 Old 12-28-2013, 12:50 PM - Thread Starter
panzer's Avatar
I know that the ge is a 3 channel passive and the ml is a powerered, but my thought process is that the ml would enable me to sell my receiver {pioneer elite sc 65), and buy a quality sub, but I am looking for how the 2 stack up musicly as they both use the folded tweeter that I am looking for, ht is not that important to me so I am leaning towards the ml.,but still looking for opinions,.also if ge or ml are coming out with new versions at ces, thanks
panzer is offline
post #2 of 4 Old 12-28-2013, 01:20 PM
tkurkowski's Avatar
Is your TV wall mounted or sitting on a stand? Because if on a stand the ML is 5" tall and may block the IR remote sensor on your TV, thus you may have to raise the TV up (like a plywood base under the TV's base). Welcome to the little-known issue of the world of high-quality soundbars (i.e. soundbars containing larger mid-range speakers) with TVs that aren't wall-mounted.
See the review of the GE soundbar I just posted - its height doesn't block the IR sensor of my 55" TV.
tkurkowski is offline
post #3 of 4 Old 12-28-2013, 10:00 PM - Thread Starter
panzer's Avatar
no problem on size, tv sits 6 inches above the stand
panzer is offline
post #4 of 4 Old 12-29-2013, 04:23 AM
tkurkowski's Avatar
I just noticed you live in the Baltimore area. That's where GoldenEar is - drop in and talk to them.
Ted
Reply Soundbars
Pioneer Elite Sc 65 9 2 Channel Thx Select 2 Plus A V Receiver
User Tag List
