Harmony One remote with HW-D551 soundbar - AVS Forum
post #1 of 6 Old 12-29-2013, 08:13 AM - Thread Starter
GWBancroft's Avatar
I have a hw d551 soundbar, and a harmony one remote. I am having some issues because I have a Blu ray player and my Xbox both connected to the soundbar via hdmi (using the arc input on the tv). The problem is that the Blu ray player is anynet+ capable and so will automatically switch the input on the soundbar, etc...but the Xbox will not. Is there any way to reconcile this with the remote, so it may know which input the soundbar is on? I'm considering buying the newer smart control remote system....would this help my problem?
Any help would be appreciated! Thanks folks!
GWBancroft is offline
post #2 of 6 Old 12-29-2013, 10:12 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 47
Connect the blu-ray and the Xbox directly to the sound bar. If you have another device like a cable/satellite box connect the HDMI directly to the TV and an Optical to the sound bar from it. Turn off CEC and ARC (any net) in all your devices. Then set up your Harmony and it should work fine. ARC and CEC interfere with what your Harmony is trying to do. Let the Harmony do the switching of your devices. ARC and CEC is nice in theory but in the real world they tend to cause more problems than they solve.
ttlnb is offline
post #3 of 6 Old 12-31-2013, 02:12 PM - Thread Starter
GWBancroft's Avatar
Only problem with that is that ARC functionality is dependent upon Anynet-CEC being turned on.....
post #4 of 6 Old 12-31-2013, 10:31 PM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 47
That's why I said connect the sound bar with an optical cable from the TV and do not use ARC.
ttlnb is offline
post #5 of 6 Old 01-01-2014, 11:19 AM - Thread Starter
GWBancroft's Avatar
Guess ARC isn't for folks like me with universal remotes.....oh well. Thanks for the help.
post #6 of 6 Old 01-01-2014, 11:39 AM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 47
ARC and CEC are evil and not for most people:-)
ttlnb is offline
Reply Soundbars
Logitech Harmony One Advanced Universal Remote
User Tag List
