Can someone explain the "DRC - Min, Standard, Max" please? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-02-2014, 01:26 PM - Thread Starter
Lynch79's Avatar
I have a Samsung HW-F450 soundbar and it has a 'DRC' funtion. In the manual it says..
This feature balances the range between the loudest and quietest sounds. You can use this function to enjoy Dolby Digital sound when watching movies at low volume at night.
So when I press the DRC button I get these options - DRC MIN > DRC STANDARD > DRC MAX
Can you guys please explain to me in more detail what this means please? The only other thing I read elsewhere was "The higher the setting the more pronounced the voices will be".
I have tried it to see if I notice any difference but its hard to tell...
Lynch79 is offline
post #2 of 4 Old 04-04-2014, 01:24 AM
Pipp's Avatar
it just gives you a wider variety of what you reading the manual
Pipp is offline
post #3 of 4 Old 04-04-2014, 01:26 AM
Pipp's Avatar
I have the same soundbar it's great just run hdmi not optical.
Pipp is offline
post #4 of 4 Old 04-04-2014, 12:31 PM
ttlnb's Avatar
Quoted: 14 Post(s)
Liked: 49
DRC = Dynamic Range Compression. It limits the dynamic range of a program. If you are viewing a program with normal dialogue and then an explosion happens it will limit how loud the explosion is played. I would leave it off or minimum if you wan to get the full audio experience. If you listen at night or have a baby sleeping it might we worthwhile to use this feature so nothing gets too loud.
ttlnb is offline
Reply Soundbars
Samsung Hw F450 2 1 Channel 280 Watt Soundbar
