ILIVE Soundbar to my tv help - AVS Forum | Home Theater Discussions And Reviews
Old 01-09-2014, 03:40 AM - Thread Starter
Nodakskip's Avatar
At black friday a few months ago I got a Emerson 50 inch tv. I also grabbed a ILIVE bluetooth 37inch soundbar on a whim since there was one left.
The tv has a Digital Audio Out Coaxial.
The sound bar doesn't have that. It does have a Red and White coaxial input for audio for older tvs. But the digital input it has is a Optical In port.
 Is there a cable that can convert those two?
I am looking for a cord that I can have the audio down or off on the tv and be able to raise the sound on the bar.
Nodakskip is offline
Old 01-09-2014, 05:15 AM
Doctego's Avatar
Liked: 42
You can get one of these adapters:
http://www.monoprice.com/Product/?c_id=104&cp_id=10423&cs_id=1042302&p_id=2947&seq=1&format=2#description
If you don't have them, you will also need the appropriate cables to go from your TV and to your soundbar.
We are here to help you. Please help us to help you. If you provide incomplete information, at best, we can give you an incomplete response.
Doctego is offline
