Connecting to Soundbar Via Bluetooth? - AVS Forum | Home Theater Discussions And Reviews
Old 01-23-2014, 07:46 PM - Thread Starter
surfer860904's Avatar
I have the Vizio S3821w-C0 38-inch 2.1 Home Theater Sound Bar with Wireless Subwoofer , And i would like to know if i could use a simple thumbnail bluetooth dongle, plugged into my tv’s usb, to pair my tv with the sound bars’ bluetooth?
surfer860904 is offline
Old 01-24-2014, 02:14 PM
TdotLee's Avatar
I would doubt it. Most TV USB ports are designed to use an external media source or for service use, not for an audio pass through connection. A TV's USB functions are usually accessed through some type of app or different "Home" screen which functions as a separate individual mode. Similar to the way each individual input functions.
Are you just trying to eliminate running a cable to the TV? I would suggest sticking with using an optical, HDMI, or some other cable. The sound quality will be better.
surfer860904 likes this.
Panasonic TC-P60ST60 Plasma
Sony HT-CT660 Sound bar
Harmony 650 Remote
Google Chromecast
Sony Playstation 3
TdotLee is offline
Old 01-25-2014, 03:10 PM - Thread Starter
Thanks TdotLee.
You got it, I'm just trying to see if I can hook it up without having to run an audio connection to it.
If I could, It would increase my options for placement.
Vizio S3821w C0 Sound Bar With Subwoofer
