Sony HT-CT660 NO VIDEO/AUDIO - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-27-2014, 03:37 AM - Thread Starter
Lhoudini's Avatar
Hi guys! (First I ask sorry for my bad english)
I got a strange problem with my new soundbar.
Here's my connection...
PS4 (HDMI OUT) --> HDMI IN 1 / HT-CT660
B/R PLAYER (HDMI OUT) --> HDMI IN 2 / HT-CT660
HT-CT660 HDMI TV OUT (ARC) --> HDMI IN 3 (ARC) / SAMSUNG UE55F8000
After installation no problem, it works fine, Samsung Tv Controller can set Volume Up/Down and so...
I switch off the TV.  After 2/3 hour I power on the TV (HT-CT autostart), TV input on HDMI3 (ARC) and HT-CT input on HDMI1 or HDMI2, NOTHING. No audio, no video. (Samsung show "No input" screen and soundbar mute)
I disconnect every cable, switch off, switch on several times... and finally, with the SAME configuration, it works fine again!
What can I do? It's so strange! Thanx
Lhoudini is offline
post #2 of 5 Old 01-27-2014, 05:15 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
You need to use the Sony soundbar remote to control the soundbar and you may have to configure a setting or two in the soundbar settings menus to disable the HDMI control. Read the manual carefully for more info on how to do that.
LexInVA is offline
post #3 of 5 Old 01-27-2014, 05:19 AM - Thread Starter
Lhoudini's Avatar
So is the HDMI control the problem? I need to disactivate it?
Thanx for the response
Lhoudini is offline
post #4 of 5 Old 01-27-2014, 09:10 AM
LexInVA's Avatar
Quoted: 518 Post(s)
Liked: 218
That would be my first guess, yes. Disable it on the TV and the soundbar and that might clear up your problem. Some mixed-brand configurations don't play well over HDMI when it comes to CEC and handshakes, so I keep all my stuff in a single brand - particularly Sony - for piece of mind.
LexInVA is offline
post #5 of 5 Old 01-28-2014, 01:36 AM - Thread Starter
Lhoudini's Avatar
Perfect, it works! Thanks!
Lhoudini is offline
Reply Soundbars
Sony Ht Ct660 46 Inch Sound Bar With Wireless Subwoofer
