Harman Kardon SB 26 - Volume Jump - Please Help! - AVS Forum
post #1 of 8 Old 02-09-2014, 06:06 PM - Thread Starter
Isenweez's Avatar
Just bought a new Harman Kardon SB 26. Like it so far but have a weird issue that I do not understand. The lowest step on the volume is nearly mute but when you press volume up just once it jumps drastically? There seems to be no in between at the lower level? Is this how the unit is meant to work or is there a problem? Has anyone else encountered this?
It is hooked up via Red and White RCA to 2010 Samsung HDTV. Not sure if that has any bearing on the issue though.
Any thoughts are very much appreciated!
Isenweez is offline
post #2 of 8 Old 02-12-2014, 09:16 AM
Scandy's Avatar
Yes, I have read other posts where others have complained about the same problem. For example, take a look at the 5th post in this thread:
http://www.avsforum.com/t/1511045/harman-kardon-sabre-sb35
The person that posted there (kappa12), later told me that he returned the SB26 for the SB35. He said the SB35 had a more gradual increase in volume level and he was happy with it. Personally, I don't watch TV with the volume that low, so I am happy with the SB26.
Scandy is online now
post #3 of 8 Old 02-12-2014, 11:03 AM - Thread Starter
Isenweez's Avatar
Thanks for the info Scandy,
That is very helpful as I couldn't find any other posts regarding it.
Much help! Thx!
Isenweez is offline
post #4 of 8 Old 08-26-2014, 04:35 PM
gp-se's Avatar
Harman has released a firmware update to fix the volume issue:
http://ca.harmankardon.com/harman-ka...k-sb-2630.html
gp-se is offline
post #5 of 8 Old 08-27-2014, 02:55 PM
Scandy's Avatar
Wow! Thanks a lot for pointing that out! I never would have realized that there was a firmware update for the SB26.
Thanks gp-se!
post #6 of 8 Old 08-27-2014, 03:17 PM
gp-se's Avatar
I installed it last night, it works perfect now! No more loud volume difference from 1 - 2. I am so happy now, because besides the volume issue, this is the best soundbar I have owned. I tried a few different ones before getting the SB 26, now that the volume is fixed, it is perfect.
gp-se is offline
post #7 of 8 Old 08-28-2014, 02:24 PM
Scandy's Avatar
I just installed the firmware update and it helped a lot! I like it!
I cannot find the firmware update on Harman Kardon's US website (that is why I did not know that the new firmware existed). I wonder why it is on the ca website and not the us one?
When I checked my firmware version, I had MCU version 21. The new software was MCU version 25. I wonder what else was changed in versions 21-25. It could be my imagination, but I think it sounds better now.
post #8 of 8 Old 08-28-2014, 04:51 PM
gp-se's Avatar
mine had MCU 23, I haven't noticed a sound quality difference, but the volume fix is much appreciated.
gp-se is offline
Reply Soundbars
Harman Kardon Sb26 Advanced Soundbar With Bluetooth And Powered Wireless Subwoofer
User Tag List
