Need more HDMI inputs - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-16-2014, 11:54 PM - Thread Starter
phas3's Avatar
Quoted: 24 Post(s)
I have a Sony CT660 and I've used up all the HDMI on the sound bar, is there a way to allow more HMDI to be used with the sound bar?
phas3 is offline
post #2 of 7 Old 06-17-2014, 12:10 AM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
afrogt is offline
post #3 of 7 Old 06-17-2014, 10:18 PM - Thread Starter
phas3's Avatar
Quoted: 24 Post(s)
Originally Posted by afrogt View Post
So would I connect this switch into one of the HDMI inputs on my sound bar, and also would I be able to use my Harmony Ultimate remote to have it switch hdmi inputs to the right one?
phas3 is offline
post #4 of 7 Old 06-18-2014, 06:48 AM
afrogt's Avatar
Liked: 755
I guess you would connect the switch to one of the HDMI nputs on the sound bar. Will the Harmony work with it? Probably, but check with Harmony to be sure.
afrogt is offline
post #5 of 7 Old 06-20-2014, 07:50 PM
Nukem's Avatar
Quoted: 13 Post(s)
Yeah, your Harmony will work.
Nukem is offline
post #6 of 7 Old 06-20-2014, 08:17 PM
asanievas22's Avatar
it should still be able to work
asanievas22 is offline
post #7 of 7 Old 06-27-2014, 04:31 PM
TahoeDust's Avatar
Quoted: 41 Post(s)
Are all the ones in your TV being used? You could use those plus ARC to get the sound to the soundbar.
TahoeDust is offline
Reply Soundbars
