Paradigm soundscape - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-09-2014, 08:47 PM - Thread Starter
Liked: 0
Paradigm soundscape
Hey guys, I just received my paradigm soundscape 5.1 soundbar. When I turn it on it makes a static noise that increases in volume until it makes a very sharp pop. Is this normal? The pop is pretty loud. After that it appears to work okay but seems kind of quiet. It's hard to hear people talking even with the volume at around 50 units.
I really hope I didn't just buy a 1500$ paperweight...
tetrafluoroethane is offline
post #2 of 8 Old 07-10-2014, 07:27 PM
RFK54's Avatar
Quoted: 23 Post(s)
I've noticed the 50-60 or even 70 volume setting required for hearing dolby and especially dolby 5.1 movies but wasn't bothered by it since going through my TV speaker the volume was often close to 100 and still wasn't clear. When I watch an older title without surround processing the volume is often much louder and I'm fine with volume set at 30-40. I have mine hooked up through my Oppo bluray player since my TV won't output 5.1 sound from optical. I've also connected my CD player through the analog output and background level music listening is fine at 30-35. I'm really very pleased with the sound and clarity of the Paradigm Soundscape and I've never noticed an increasing static and pop at startup, only a five second or so delay as the display starts up. Possibly the optical cable or grounding issue. I hope it works out for you.
RFK54 is offline
post #3 of 8 Old 07-11-2014, 05:36 PM - Thread Starter
Liked: 0
I didn't even consider that the TV may not be able to put out 5.1.. I'll have to look into that. I've already talked to the retailer and they had me RMA. I agree, it sounded like a ground issue. Other than that I really like it.
post #4 of 8 Old 07-12-2014, 11:47 AM
taichi4's Avatar
Quoted: 316 Post(s)
Liked: 152
Many current HDTVs don't output 5.1. What kind if set (and model) do you have?
Other than that, are your cables fairly new, and are (were) your connections solid?
taichi4 is offline
post #5 of 8 Old 07-13-2014, 08:35 PM - Thread Starter
Liked: 0
I have a Samsung un46eh5300. Nothing special. The connections seemed fine and I was using the optical cable that came with the soundbar. Actually it's me first time using optical so it surprised me how easy it was
post #6 of 8 Old 09-10-2014, 07:20 PM
Liked: 0
I have the same setup. It does not make any static or popping noises but it does have to run the volume up to 30 before you get anything out for sound
chriscalabro is offline
post #7 of 8 Old 01-09-2015, 09:44 AM
mmick6175's Avatar
Just bought the soundscape and also having a problem with intermittent static. Did you ever find out what the issue was with your unit after you returned it. Unfortunately, I bought mine by mail order from Audio Advisors so returning will be a pain.
mmick6175 is offline
post #8 of 8 Old 01-09-2015, 09:30 PM
Quoted: 97 Post(s)
Sending a Dolby source into the soundscape the sound lacks- DTS is amazing. The only time I had issue with sound quality was when I was using cheap Amazon cables. I replaced all my hdmi and optical cables with audioquest cables and never had another issues. People who say high quality cables are a gimmick are crazy.
carguy85 is offline
Reply Soundbars
