AT&T DVR, Soundbar and HDTV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-16-2014, 08:23 AM - Thread Starter
Liked: 0
Unhappy AT&T DVR, Soundbar and HDTV
I have a Philips Soundbar Model #HTL2101 /F7 with Coax
I have an AT&T DVR with Coax, Audio/Visual Output, Optical Output Output and HDMI
I have a ProScan PLEDV2845A
When I first brought the soundbar home, I read the instructions and updated the Soundbar with the latest firmware.
I then connected it directly to the HDTV via a Digital Cable.
It worked, but the sound was a little low.
Then the power went out and when the TV and DVR and Soundbar came back up, soundbar was not working and now I have no idea how to get it to work again.
Should I attached the Soundbar directly to the DVR instead? If so, do I use Optical Cable, Digital Cable or A/V (Red/White/Yellow) output?
If not connect the sound bar directly to the DVR, do I connect it to the TV? If so, is there any special configuration on the ProScan HDTV?
Please help - the ProScan HDTV Audio output sucks..
Jeff
Bro Jeff Wolfe is offline
post #2 of 3 Old 07-16-2014, 06:03 PM
JChin's Avatar
Quoted: 329 Post(s)
Liked: 199
Hi Bro Jeff Wolfe, use optical or digital coaxial cable (both output the same).
AT&T DVR -> HDMI cable -> Proscan TV
AT&T DVR -> Optical cable -> Soundbar
This should give you an option to watch cable box with and without the soundbar.
JChin is offline
post #3 of 3 Old 07-30-2014, 12:35 PM - Thread Starter
Liked: 0
Thanks JChin.. I will try that setup.
Peace,
Bro Jeff
Reply Soundbars
dvr , hdtv , soundbar
