Is it possible to have DirecTV remote control sound bar volume - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-18-2014, 04:51 PM - Thread Starter
carillon's Avatar
Quoted: 155 Post(s)
Liked: 47
I have a DirecTV HR34 receiver connected to a Sharp 60" TV via HDMI. The Vizio sound bar is currently connected to the TV's optical audio out. Is there any way to have the DirecTV remote control the sound bar volume? I'd like to be able to only use the DirecTV remote and not have to use the sound bar remote to control volume.
carillon is offline
post #2 of 10 Old 07-18-2014, 04:57 PM
tubetwister's Avatar
Location: The Outer Limits....Don't trust any air I can't see ☺
Quoted: 1384 Post(s)
Liked: 622
Optical audio out level is fixed . OTOH if you used an analog 2.0 stereo output from TV to sound bar when using Direct TV and your TV has an variable analog audio output option (usually enabled in sound settings menu ) that would work I have a bedroom TV set up like that on Dish. .
tubetwister is offline
post #3 of 10 Old 07-18-2014, 06:05 PM - Thread Starter
carillon's Avatar
Quoted: 155 Post(s)
Liked: 47
Thanks... so if I connect it the way you suggest, the DirecTV remote is only configured to control the DirecTV receiver and the TV. When adjusting the volume with the DirecTV remote, it will adjust the sound bar volume? That would be great!
carillon is offline
post #4 of 10 Old 07-18-2014, 06:25 PM
Liked: 622
Yes that is correct (if your TV has that feature ) my Dish remote adjusts the variable audio out signal on the TV .
My TV (Sony ) you can run fixed analog audio out or variable analog audio out with the TV speakers on or off and also set the volume offset between the variable audio out and the TV speakers (if you still have then enabled ) and at the same time still have tour 5.1/7.1 optical PCM data output available .
post #5 of 10 Old 07-18-2014, 06:29 PM - Thread Starter
carillon's Avatar
Quoted: 155 Post(s)
Liked: 47
Thanks, I'll give it a shot tomorrow.
carillon is offline
post #6 of 10 Old 07-20-2014, 08:52 PM
Liked: 0
To borrow the answer from another forum:
Step 1 is to find the soundbar code for your device and program in AV1 or AV2 to control it. Then,
http://www.directv.com/learn/pdf/Rem...RC65forWeb.pdf
Page 11 & 12.
The remote ships with the volume locked to the TV, so that the volume control controls the TV regardless of the position of the slider.
The first section on Page 11 tells you how to UNLOCK the volume control, so that you have to move the slider to TV to control the TV volume.
The next section, top of Page 12, tells you how to LOCK the volume on one of the other selections.
Keep in mind, once you do this you will ONLY control your soundbar volume and no longer control the TV's volume from the DTV remote.
LarzMN is offline
post #7 of 10 Old 07-21-2014, 05:17 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Optical audio out level is fixed . OTOH if you used an analog 2.0 stereo output from TV to sound bar when using Direct TV and your TV has an variable analog audio output option (usually enabled in sound settings menu) that would work. I have a bedroom TV set up like that on Dish.
That is the best way to do it - but most TVs don't have analog audio out these days and even fewer have the menu option to select Variable Audio Out - but if you have it you should use it.
You didn't mention which soundbar you have, but my Dad's Visio soundbar will imitate the TV volume remote codes - there is a way to program it to see the volume up and volume down from your remote and adjust its volume - check your soundbar manual. That would be another way to get remote control volume.
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #8 of 10 Old 07-24-2014, 06:20 PM - Thread Starter
carillon's Avatar
Quoted: 155 Post(s)
Liked: 47
Page 11 & 12.
Thanks for the reply, I'm going to try this in the morning!
carillon is offline
post #9 of 10 Old 07-25-2014, 12:16 PM - Thread Starter
carillon's Avatar
Quoted: 155 Post(s)
Liked: 47
Worked like a champ except the sound bar will turn itself off after a period of inactivity which is not controllable with a setting. If i can find a DTV remote code that will not only allow the remote to control the volume but also turn the sound bar on/off I'll be set!
carillon is offline
post #10 of 10 Old 07-29-2014, 11:07 AM
cleanfreak's Avatar
Liked: 0
I was in your same boat. I finally broke down and spent $120 on the harmony smart remote control and never looked back. All other remotes are now dust collectors.
It operates my Samsung TV, DirecTV, and soundbar all without any issues. The app for the phone also changes the volume on the soundbar by simply swiping up or down on the screen.
cleanfreak is offline
Reply Soundbars
