Yamaha YHT-S401 rear speakers....best options - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 07-21-2014, 05:13 PM - Thread Starter
davnkaz's Avatar
Hi all,
I hav this soundbar in my front room, and would like to utilise the rear speaker option, but preferably with wireless speakers.
A few questions:
  • Does anyone actually have this set up and does it make a difference.
  • Anyone recommend some standalone wirlesss speakers I could use to have this working if it is worth it that is.
P.S. I got rid of my old wired dvd all in one system, and am happy with this soundbar, but actually miss the 5.1, as virtual surround sound I don't believe actually cuts it.
Anyway, as always any advice is appreciated.
davnkaz is offline
post #2 of 3 Old 07-21-2014, 05:32 PM
mtn-tech's Avatar
Quoted: 232 Post(s)
Liked: 178
Page 31 of your owners manual states: "Surround Left and Right (1KHz, 1% THD, 6 Ohm) 45w + 45w"
It is rated to drive 6 ohm speakers, so find a speaker that is 6 ohms or higher (most are 8 ohms nominal) and you will be fine.
Polk Audio OWM3 On-Wall Speaker (Pair) - $99, free shipping
2-Ch (HT L/R): Oppo BDP-105 BD, Adcom GFP-750 pre, Bryston 10B Sub Xover, Bryston 4BSST2 / Paradigm Signature S4 v.2 (L/R), (2) SVS SB12-NSD (Subs)
Home Theater: Bryston 4BSST2 amp / Paradigm CC-590 (C), Outlaw 7700 amp / (4) Def Tech UIW-RSSII (LS/RS/LB/RB), Samsung 46” 3D LCD
mtn-tech is offline
post #3 of 3 Old 07-22-2014, 08:33 PM - Thread Starter
davnkaz's Avatar
Hi there,
Thanks for the answer, yes have "googled" solutions, and was more after recommendations, is it worth it and best wirelsss options.
All good, and thanks for the advice.
davnkaz is offline
Reply Soundbars
