Can't connect LG sound bar to SHARP TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-04-2014, 09:44 AM - Thread Starter
Liked: 0
Hi, sorry for the long post, but I want to be as clear as possible. I want to connect my new LG sound bar (NB4540) to my 70" Sharp (LC70LE857U). Both are ARC and CEC enabled, so I tried to connect them using HDMI between them to get the sound of the TV directly on my bar.
I have activated everything that the manual says that I need to activate on the TV in order for this ARC connection to work. The bar does not require any setup since it indicates that it will switch to ARC input as soon as it detects it. However I can't make them work with this method. The sound still comes from the TV speakers (I used the Netflix app from the TV for testing purposes), and the Sound bar just stays there doing nothing. A curious thing is that when I turn off the TV using its remote control, the sound bar also turns off... but that is all that it does.
I tested an optical cable that comes with the bar, and it works, it sends the sound from the TV to the bar, but that doesn't solve the problem with the ARC connection, and as far as I know, this connection has lower sound quality than using HDMI, so I don't want to use it.
I have an LG 42" TV, which is 2 years older than the Sharp TV, also ARC and CEC enabled. I wanted to test the bar and the cables on this TV to see it the problem was there, so I connected the bar using the same method (HDMI cable between ARC ports, running Netflix app) and it worked! I went to the TV menu, activated the ARC feature, and the TV and the bar did the rest. The soundbar automatically changed to ARC input, and the TV remote now controlled the soundbar. It was a relief. Sort of...
Any ideas of how to setup the ARC connection with the SHARP?
Regards
charlyposho is offline
post #2 of 5 Old 08-04-2014, 04:57 PM
HDMI Guy's Avatar
Quoted: 177 Post(s)
Liked: 45
Regards
Have you tried it with the Sharp TV speakers turned off. Also make sure you are using HDMI 1 on the Sharp.
HDMI Guy is offline
post #3 of 5 Old 08-05-2014, 07:56 AM
hammerdwn's Avatar
Quoted: 173 Post(s)
Liked: 53
...as far as I know, this connection has lower sound quality than using HDMI, so I don't want to use it....
Not true in a soundbar to Tv setup. The best that your Tv can send out via either type of connection is 5.1 dolby digital. If you are connecting something that sends HD audio like DTS Master HD or Dolby True HD, to an AVR then yes HDMI is needed. Your Tv and your soundbar cannot do HD audio so optical is same as hdmi for you.
XBR-65Z9D | AVR-X2200W | UBD-K8500 | JRMC HTPC w/9 cable tuners | Fluance SV 7.1 + eD A3-300
hammerdwn is offline
post #4 of 5 Old 08-10-2014, 10:03 PM - Thread Starter
Liked: 0
Yes, I turned them off. Yes I used HDMI1 as I said.
In the end, I decided to connect my PS3 directly to the bar, and then the bar to the Tv. I've heard that this way is better than using the ARC connection, since the PS3 sends directly the sound to the bar, instead of passing through the Tv. Is this correct?
Also, i connected the TV to the bar using the optical connection, to listen the cable, Netflix, and Youtube on it.
Both of them (the PS3 and the TV) are configured to Bitstream output. I feel ok with this config. The bar reads Dolby Digital from the Tv, and DTS 2.1 from the PS3. I guess the bar I'm using can't read HD audio formats.
What do you think? Especially about the bitstream part.
post #5 of 5 Old 08-10-2014, 11:13 PM
JChin's Avatar
Quoted: 367 Post(s)
Liked: 210
Hi charlyposho, on the Sharp set Aquos Link Control and Audio Return Channel to "On" (may have to power off and back on the TV and Sound bar after the settings).
JChin is offline
Reply Soundbars
