sony sound bar not working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-13-2014, 09:22 PM - Thread Starter
ruthinor's Avatar
I have a sony sound bar (HT-CT260/HT) which was working perfectly well this afternoon. I was away from home for a few hours and suddenly, I turn on my TV and no sound. All the lights are on as they should be which seems to indicate that the connections are fine. Any suggestions would be welcome.
ruthinor is offline
post #2 of 3 Old 08-14-2014, 04:55 AM
Mattopotamus's Avatar
Quoted: 1484 Post(s)
Liked: 1131
check your TV settings. Did it somehow switch back to internal speakers?
Mattopotamus is offline
post #3 of 3 Old 08-14-2014, 08:34 AM - Thread Starter
ruthinor's Avatar
the mystery continues
Thanks for your reply. I have an LG "smart" TV, about 2-3 yrs old. The internal sound has no interference with the sound bar, just turn it to zero to get the sound bar full effect. If you turn up the internal sound, you just hear two different sounds, whose timings are slightly different. This AM I tried it again and it worked perfectly fine! So I'm left with the fact that I have no idea why it did not work yesterday PM and seems to be fine again today. I did not change any settings.
ruthinor is offline
Reply Soundbars
