Recommend a Soundbar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-16-2014, 12:33 PM - Thread Starter
jmk2888's Avatar
Hi All,
It's been a while since I have posted. Please give me some recommendation on a sound bar.
I have a 65" Samsung U8550 and a Onkyo TX-SR605 with JBL 12" down firing subwoofer.
My budget is no more than $1,000 for a Sound bar and so far I'm looking at Mythos SSA-42 or 50. I definitely wants to use my Receiver to power the sound bar.
Any suggestions is greatly appreciated.
jmk2888 is offline
post #2 of 4 Old 09-10-2014, 07:10 PM
Liked: 0
Paradigm
Take a look @ Paradigm. They have a $900 option with a wireless sub which sounds awesome.
chriscalabro is offline
post #3 of 4 Old 09-13-2014, 02:37 PM
RayGuy's Avatar
Quoted: 733 Post(s)
Liked: 596
Check out Golden Ear.
RayGuy is offline
post #4 of 4 Old 09-14-2014, 01:52 PM
They_call_me_Roto's Avatar
Quoted: 253 Post(s)
Liked: 180
The Definitive Technology Mythos SSA 50 has wonderful sound considering that it is a soundbar and has 4" drivers. Aside from the Def Tech, You should also take a look at the GoldenEar SuperCinema 3D Array or the Episode ES-500-SNDBAR-50-BLK. Those are both in your price range and they are both approximately 49" wide which would make them a good match for your TV. The GoldenEar and the Episode are two of the widest off-the-shelf soundbars. If you wanted a soundbar that is wider that those two, you would probably have to go with a custom made one like a Leon Horizon SB.
Packing a lot of sound into a small room.
268 square feet/2144 cubic feet
7.2 surround sound.
They_call_me_Roto is offline
Reply Soundbars
