You are mixing up three differents models. Nonetheless, you are asking should I buy a VW or a Mercedes. The answer depends on how much you want to spend and what features you desire. All will sound better than TV speakers in an Apt. Good Luck.
If you want real bass, forget the 54 inch 3.0 Vizio. The description says "deep bass" but all I heard was a lot of mid bass & the highs are so-so at best. Any of the Yamaha 3.0 models sound light years better in both departments for much less money.
If you still want a Vizio 3.0 I have a new one used for about 1 hour for sale real cheap.
The Yamahas I mentioned use an internal subwoofer, so won't have near the impact of a system with a separate subwoofer. I was comparing to Vizios with internal bass speakers.
54" is a tad better sounding than the 42 " Vizio 5.1 soundbar (i have both models) the 54" has all the input options of the 42" Plus Hdmi in/out that the 42" lacks
it depends on the size of the tv you wish to pair it with and if hdmi sound connectivity is an option you need
Another thing to consider would be if you care about lossless audio from blu ray discs namely DTS-HD-MA or Tru-HD. The 54"version has an HDMI Input/ Output that makes this possible while the 42"doesn't. If you have a capable receiver or a blu ray player like the Oppo 103 with extra HDMI Inputs you can connect the 54" version via HDMI to enjoy lossless audio.
Related Threads
AVS Forum
34M posts
1.5M members
Since 1999
