Convert Downloaded 3d Content to Checkerboard? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-23-2010, 08:42 AM - Thread Starter
Justin-Dawson's Avatar
Are there any programs out there that can convert downloaded 3d content into the checkerboard format? I'm not talking about ripping a BD, I want to be able to download SBS content, convert it to a checkerboard file and then stream it to my ps3. Possible?
Justin-Dawson is offline
post #2 of 10 Old 08-23-2010, 10:27 AM
taz291819's Avatar
Quoted: 78 Post(s)
Liked: 55
Stereoscopic player converts to checkerboard on the fly, but I don't think there's a way to then stream it to your PS3.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
JBL Studio Series (Front, Center, Right), JBL 250W Sub, Kenwood Rears, Onkyo Atmos Upfiring
LG UP970 UHD Player
Nvidia Shield TV
taz291819 is offline
post #3 of 10 Old 08-23-2010, 01:34 PM - Thread Starter
I want something like that but I want to be able to save the converted file as a video in checkerboard format and then put it on my network HD to stream to my PS3.
Bascially I'm trying to avoid buying the Mits adapter (plus Gefen since I have a Samsung) or buying the Panny BD player. I'm still holding out hope that the PS3 3d BD update supports checkerboard... but it's not looking good. That, and I'm not willing to buy a 3d solution that requires me to update my AVR... while degrading picture quality (crushing blacks). The worst part is that if Mits didn't try to block Samsung owners by implementing the EDID restrictions in the first place, people wouldn't be having AVR issues.
For PS3 games, I'm fairly confident that 3rd party developers will implement checkerboard support on the front end. I understand Sony's reasoning for not supporting checkerboard (selling TVs) but 3rd party developers want to sell games. Avatar proved that even mediocre games can sell well when checkerboard is supported. As Crysis 2 will support 3d on the xbox, I'm confident that CryEngine 3 has checkerboard support... which I believe will become the new standard for first person shooters... until Unreal 4 anyways.
post #4 of 10 Old 08-23-2010, 07:44 PM
Ken H's Avatar
So you understand Sony but not Mitsubishi?
'Better Living Through Modern, Expensive, Electronic Devices'
Ken H is offline
post #5 of 10 Old 08-23-2010, 09:16 PM
PaulGo's Avatar
Quoted: 175 Post(s)
Liked: 95
Sony has stated all 3D games will be in 720p. Unfortunately the 3D dlp chip in Samsung and Mits TVs only works with 1080p. So the software use of checkerboard in new games is unlikely.
PaulGo is offline
post #6 of 10 Old 08-24-2010, 06:22 AM
Waltm's Avatar
mplayer/mencoder for Linux and Windows should be able to do it. There is a post on the second page of this thread http://www.mtbs3d.com/phpbb/viewtopic.php?f=27&t=4521 that deals with checkerboard output.
This whitepaper contains an Avisynth script to convert left and right files in to checkerboard.
The alpha mask mentioned in the whitepaper can be found at the bottom of this page.
Waltm is offline
post #7 of 10 Old 08-24-2010, 10:05 AM
taz291819's Avatar
Quoted: 78 Post(s)
Liked: 55
I'm not sure if it's possible to save content in checkerboard, unless checkerboard is the same as Multi View (Tiled).
The reason I say this is because in Stereoscopic Player, you have to select the method that the original file is in, and checkerboard isn't an option.
Vizio P65-C1 (2016)
Onkyo Tx-NR656
LG UP970 UHD Player
Nvidia Shield TV
post #8 of 10 Old 08-24-2010, 02:26 PM
hugh_jainus's Avatar
my understanding is that video saved in checkerboard format would result in huge unmanageable files.
hugh_jainus is offline
post #9 of 10 Old 08-24-2010, 02:56 PM
walford's Avatar
But you can save the original compressed for transmission MPEG2 or MPEG file and then output it in decoded and decompressed checkerboard 3D video format.
walford is offline
post #10 of 10 Old 08-24-2010, 03:01 PM
almostinsane's Avatar
Quoted: 47 Post(s)
Liked: 42
I thought there were two options, select the file format and then the output format? I haven't used Stereoscopic player in a while but when I had the nVision setup I think this is the way it rolls. Select SxS for the file then checkerboard for the output.
almostinsane is offline
Reply 3D Content
