monsters vs. aliens on ps3??? - AVS Forum | Home Theater Discussions And Reviews
Old 09-21-2010, 01:36 AM - Thread Starter
yibs's Avatar
I have 2 ps3's and updated them both to v3.50. I have monsters vs. aliens 3d blu ray from the samsung starter kit and when I pop it in either one it doesn't acknowledge it. There is no loading and no errors, its as if i didn't put a disk in. I called samsung and they said it only works in samsung 3d blu ray players. Just wondering if anyone can confirm this or if I have a faulty disk.
yibs is offline
Old 09-21-2010, 02:12 AM
audiovideoholic's Avatar
Quoted: 596 Post(s)
Liked: 192
No, that is false information. Do you have a picture of PS dashboard on the tv? Are you running a reciever in the mix?
audiovideoholic is offline
Old 09-21-2010, 02:21 AM
krackkomik's Avatar
Fat PS3 updated. PN58c7000.
Runs Monster vs Aliens, Coraline and Ice Age in 3D perfectly. Like the ps3 interface much more than the Sammy 6900.
krackkomik is offline
Old 09-21-2010, 03:06 AM
jonboy71's Avatar
Quoted: 43 Post(s)
I am having the exact same problem! My Sony titles are loading and playing just fine. Samsung is wrong. The disc should play in any 3D Blu Ray player. Hopefully someone can offer some guidance on this or else we need to call Samsung back. What number did u call?
jonboy71 is offline
Old 09-21-2010, 03:31 AM
krackkomik's Avatar
Make sure the HDMI is configured for 'auto' in PS3.
MvA works fine on my US machine
Old 09-21-2010, 05:21 AM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Has anyone tried Cloudy with a Chance of Meatballs?
Curious if that works.
bad1550 is offline
Old 09-21-2010, 05:59 AM
Aaronp88's Avatar
I'm having the same problem as you both! Everyone post what version of the PS3 you have and if it works or not.
I have a 60 GB Fat PS3 and it does not work.
Aaronp88 is offline
Old 09-21-2010, 07:01 AM
Dr. A's Avatar
Just watched half of it. Equipment includes PS3 v.3.50, Laservue 75, Mits 3D kit.
Amazing. Works just fine.
Dr. A is offline
Old 09-21-2010, 07:08 AM
bad1550's Avatar
Quoted: 56 Post(s)
Liked: 41
Looks like the checkerbox does not workwithout an adapter
I was hoping not to have to purchase additional equipment for my sla750
Samsung
bad1550 is offline
Old 09-21-2010, 07:49 AM
josephcoatar's Avatar
Also can't play MVA, 'Cloudy' works fine, any suggestions?
80gb fat PS3
josephcoatar is offline
Old 09-21-2010, 08:48 AM
TonyDP's Avatar
Quoted: 306 Post(s)
Liked: 203
I've got one of the original fat 60gb PS3s that was backwards compatible (purchased July 2007) and the 3D update (v3.50) works fine for me. I watched some of Monster House and all of Bob's Big Break from the MvA disc and everything played fine with nice depth and pop (better than my BD-6900 at first blush). I've got the PS3 connected to a PN63C8000 via a high-speed HDMI cable.
Could it be there are multiple versions of the MvA disc out there as was the case with the Panasonic 3D promo?
Xbox Live: XboxPhantom
PSN: TonyDP
TonyDP is offline
Old 09-21-2010, 08:57 AM
biggdawg29's Avatar
I also have the old fat PS3 60gb. It was one of the 1st PS3's out there and Monsters Vs Aliens DOES NOT play. The PS3 doesn't recognize the disk at all
biggdawg29 is offline
Old 09-21-2010, 10:01 AM
advocate2's Avatar
Just tried MVA on my two year old PS3 120 or 150GB. MVA played fine. I have 1.4a cables to a Denon 331, to the MITs adapter then to the Mits 73735. I also tried out COTT and it worked as well.
advocate2 is offline
Old 09-21-2010, 10:08 AM
thebat68's Avatar
Ditto. Good thing I have a Panasonic BDT-300.
thebat68 is offline
Old 09-21-2010, 10:27 AM
jonboy71's Avatar
Quoted: 43 Post(s)
I'm wondering if there is a bad batch of discs. Has anyone that had no luck playing MvA on the PS3 been able to play it on another Blu Ray player. I too have an original launch, backwards PS3 that is backwards compatible. So it seems unlikely it is the unit itself since some have the same specs and it plays ok. Monster House and Cloudy play back fine.
jonboy71 is offline
Old 09-21-2010, 10:43 AM
GISMO1's Avatar
so what is needed to play 3d movies new updated 3d tv and a special hdmi cable.
GISMO1 is offline
Old 09-21-2010, 10:45 AM
HermantoWang's Avatar
I have the same problem with you
HermantoWang is offline
Old 09-21-2010, 10:54 AM
Barrok's Avatar
Mine worked if i took it directly from my PS3 (20gb model, got a couple days after release) to my pn63C8000. Using the same cable but sending it to my receiver (pioneer SC-25) I just get a flashing (dolby digital 96/24hz) text on my receiver and it never loads up causing me to hard shut down (holding my finger over the power) to get it to turn off.
I would imagine that if it can't send the video in 3d, it should go down to 2d rather than jack my system. At least thats what the C7900 I have does.
Barrok is offline
Old 09-21-2010, 10:58 AM
Sonyxbr's Avatar
Interesting. For those of you that is does not work, are you running the PS3 directly to your TV?
Sonyxbr is offline
Old 09-21-2010, 11:00 AM - Thread Starter
yibs's Avatar
I have both an old 80gig ps3 with ps2 backward compatiblity and a new slim 250gig ps3 and neither are working with MvA. I called the 1-800# on samsungs website. I'm thinking there is a bad batch of disks, I have a friend with a samsung 3d blu ray player and will try playing it over there today.
yibs is offline
Old 09-21-2010, 11:06 AM - Thread Starter
yibs's Avatar
I have both hooked directly up to my c7000.
yibs is offline
Old 09-21-2010, 11:13 AM
Aaronp88's Avatar
The problem is not related to cables or TVs. The PS3 simply does not recognize the disc. If anyone has had a PS3 with a bad blu-ray laser then they know how the PS3 acts when MVA is inserted. Nothing happens, the loading circle spins for a bit, the blue light comes on, but nothing comes up in the XMB.
From the MVA review on blu-ray.com:
"The disc was also inserted into a PlayStation 3 system running the latest firmware (v. 3.21) to see if it would play the 2D version; the system simply failed to read the disc. "
Aaronp88 is offline
Old 09-21-2010, 11:19 AM
jonboy71's Avatar
Quoted: 43 Post(s)
I would like for someone to try a disc that doesn't work on their PS3 to try it on another 3D Blu Ray player if possible to see if it's a bad disc or not.
jonboy71 is offline
Old 09-21-2010, 11:21 AM
Barrok's Avatar
So the people claiming it doesn't work don't actually see anything on their XMB under video? I see blu-ray and when i load it through my receiver it doesn't work. I am assuming you guys are talking about something different right? Where the actual disc doesn't even load?
Barrok is offline
Old 09-21-2010, 11:24 AM
jbug's Avatar
Quoted: 249 Post(s)
Liked: 127
Is the PS3 able to decode the lossless audio?
jbug is offline
Old 09-21-2010, 11:27 AM
jonboy71's Avatar
Quoted: 43 Post(s)
That is correct, it doesn't even load. Nothing pops up under video at all.
jonboy71 is offline
Old 09-21-2010, 11:37 AM
Barrok's Avatar
I have had that happen alot with other blurays. Thats why i originally got my C7900 because half my blurays wouldn't load in my PS3 (original 20gb).
I have noticed that occasionaly some won't load in my C7900 and I have determined it is cause my bluray is too cold. If i put it under my shirt, or put it in the sun for a few minutes it will end up loading. Or I put it in my ps3 and it just spins and spins and spins and that warms it up enough to put in my c7900 and have it work.
Don't ask me why it acts like this. My house is kept at 72 F so i don't think thats too cold but what ev.
Barrok is offline
Old 09-21-2010, 11:58 AM
Sonyxbr's Avatar
I am hoping to try this tonight. A friend of mine has MvA that works fine on her Samsung 3D Blu Ray player. She is supposed to bring it over and I will try it on my PS3. I only have a the Panasonic demo disk which I played last night and works and looks great.
Sonyxbr is offline
Old 09-21-2010, 12:53 PM
roylone's Avatar
I have an "old style" PS3 in which MVA will not load as reported by others. I tried it in my Panasonic BDT-350 and it loaded and played without difficulty. I therefore suspect that there is something about the disc that the PS3 does not like. I have tried the following 3D discs without difficulty in the PS3: Coraline, Cloudy with a Chance of Meatballs, Monster House and Clash of the Titans.
roylone is offline
Old 09-21-2010, 12:54 PM
thebat68's Avatar
Movie does not get recognized by my PS3 but plays fine on my Panasonic BDT-300 Blu-ray 3D player in 3D and 2D.
thebat68 is offline
