Found problem with 3D in Rio, Drive Angry - need solution - AVS Forum
post #1 of 11 Old 01-24-2012, 11:06 AM - Thread Starter
bbtrinet's Avatar
Most of my 3D movies look great. I've seen probably 20 on my blu-ray/LG passive 3D TV.
Drive Angry was a complete mess when I watched it, and now, I just saw Rio (or attempted to and had to quit 10 minutes in), and it's the same mess.
Here is what is happening. In all the other blu-rays, both images, the one for the left-eye and the one for the right-eye are the same, just moved slightly to create the 3D depth. However, in Drive Angry and Rio, the images going to the left-eye and right-eye are moved AND are different. My eyes see this as a blurry mess.
For example, in the opening sequence in Rio with the birds, I paused the action, left my 3D glasses on, and closed my left eye, and I see the birds with their mouths open, when I close my right eye, I see the birds with their mouths closed. This type of thing. This is happening in the fast-action scenes with things moving very fast. When things are moving slower, there is less of a difference, so my eyes perceive the 3D correctly.
In other fast movies, this isn't the case. For example, any Disney movie, Tangled, Lion King or Beauty and the Beast, fast moving scenes show the same image in the left-and-right eye, so my eyes have no problem with this 3D.
This seems to be an issue with either:
(a) how the blu-ray 3D was created. Do certain people have no problem with this and see this correctly?
(b) does this work for active and not LG's passive? Is LG doing something weird by showing 2 different frames, when active would show just one?
(c) are there settings which could fix this?
Has anyone else noticed this?
bbtrinet is offline
post #2 of 11 Old 01-24-2012, 11:40 AM
adpayne's Avatar
Liked: 37
I have Rio, Drive Angry, and a Vizio passive 3DTV. No problems with either BD for me using a PS3. They both look great.
Good luck in solving your issue.
Art
adpayne is offline
post #3 of 11 Old 01-24-2012, 11:49 AM
cinema13's Avatar
Quoted: 66 Post(s)
Liked: 96
Give me an example on DRIVE ANGRY and I'll check my copy.
cinema13 is offline
post #4 of 11 Old 01-24-2012, 12:11 PM
HokeySmoke's Avatar
Both of these movies were encoded with the right eye as the first stream and the left eye as the second stream. Almost all other 3D Blu-rays have the left eye as the first stream. Some Blu-ray players have a delay between left and right eyes (as reported below) when faced with this type of uncommon disc, which is a bug in the player. What Blu-ray player are you using?
http://forums.highdefdigest.com/gene...d-problem.html
If it's an LG Blu-ray player, I believe they have a fix already.
HokeySmoke is offline
post #5 of 11 Old 01-24-2012, 12:11 PM
2D3D's Avatar
Originally Posted by cinema13 View Post
Give me an example on DRIVE ANGRY.
Just ride with me one morning from home to work and you shall have an example of DRIVE ANGRY
2D3D is offline
post #6 of 11 Old 01-24-2012, 07:12 PM
brahby's Avatar
I lol'd ^^^
brahby is offline
post #7 of 11 Old 01-24-2012, 09:02 PM
cinema13's Avatar
Quoted: 66 Post(s)
Liked: 96
My daily life!
cinema13 is offline
post #8 of 11 Old 01-25-2012, 07:06 AM - Thread Starter
bbtrinet's Avatar
Thank you. I think this is exactly what I need to fix this problem.
I'll download the update tonight, and try it on my LG Blu-ray player. I'll let you know tomorrow how it went.
bbtrinet is offline
post #9 of 11 Old 01-26-2012, 05:35 AM - Thread Starter
bbtrinet's Avatar
Exactly what I needed. After doing the firmware update, Rio looks perfectly fine on my LG Blu-Ray player. I'll have to re-rent Drive Angry and see how it looks now.
I'm a lot happier with the 3D! I assumed (incorrectly) that fast-action just wasn't geared toward 3D, but I'm wrong - it's all good if your 3D blu-ray player can play it correctly.
Thank you again, HokeySmoke!
bbtrinet is offline
post #10 of 11 Old 08-15-2012, 09:24 AM
tequila66's Avatar
I have this problem right now with my two Panasonic 3D Blu-Ray players. The DMP-BDT300 and the DMP-BDT500, my tv is LG LK950S. Both have the last firm.
tequila66 is offline
post #11 of 11 Old 12-22-2012, 09:01 AM
kikkoman's Avatar
I have the problem with Drive Angry but I'm using a 3D iso file. It looks horrible. I've only tested a few movies which are ok. Just this ok is off. Need to test Rio iso as well. Using LG 5600 with new media player.
kikkoman is offline
Reply 3D Content
Blu Ray Movies , Vizio , Lg
User Tag List
